dear community,
i successfully built a hardware controller for the (music production) plugins Waves CLA 1176, CLA LA2A and Universal Audio API 2500.
Everything runs smooth under the "Control_Surface" on a Teensy 4.1.
Now i want to expand it even more and build a controller for the Distressor plugin.
I expanded the setup with a MCP23017 and got 6 more encoders running.
unfortunately i also need 3 buttons. And i have no clue how to make it work.
where can i find the little bit of code that makes the whole thing complete?
any ideas?
here is the code so far:
#include <Encoder.h>
#include <Control_Surface.h>
#include <AH/Hardware/MCP23017Encoders.hpp>
#include <Wire.h>
// Type for the MCP23017 encoders (translates encoder pulses to position)
using WireType = decltype(Wire); // The type of I²C driver to use
using EncoderPositionType = int32_t; // The type for saving encoder positions
constexpr bool IntSafe = true; // Make it safe to call `update` in an ISR
using MCPEncoderType = MCP23017Encoders<WireType, EncoderPositionType, IntSafe>;
// Type for the MIDI encoders (translates position to MIDI messages)
struct CCMCPEncoder : GenericMIDIRotaryEncoder<MCPEncoderType::MCP23017Encoder,
RelativeCCSender> {
CCMCPEncoder(MCPEncoderType::MCP23017Encoder enc, MIDIAddress address,
int16_t multiplier = 1, uint8_t pulsesPerStep = 4)
: GenericMIDIRotaryEncoder(std::move(enc), address, multiplier,
pulsesPerStep, {}) {}
USBMIDI_Interface midi;
using namespace MIDI_Notes;
const uint8_t interrupt_pin = 12;
// Create an object that manages the 6 encoders connected to the MCP23017.
MCPEncoderType enc {Wire, 0x0, interrupt_pin};
// │ │ └─ Interrupt pin
// │ └────── Address offset
// └──────────── I²C interface
// Instantiate 6 MIDI rotary encoders.
CCMCPEncoder ccencoders[] {
enc[0], // The encoder to use
MCU::V_POT_1, // The MIDI address
1, // Encoder speed multiplier
4, // Number of pulses per physical "click" of the encoder
{enc[1], MCU::V_POT_2},
{enc[2], MCU::V_POT_3},
{enc[3], MCU::V_POT_4},
{enc[4], MCU::V_POT_5},
{enc[5], MCU::V_POT_6},
// Further encoders connected directly to the Teensy 4.1 board
CCRotaryEncoder enc1 = {
{0, 1}, // 1176 1 Input
100, // MIDI address (CC number + optional channel)
4, // optional multiplier if the control isn't fast enough
CCRotaryEncoder enc2 = {
{2, 3}, // 1176 2 Output
101, // MIDI address (CC number + optional channel)
CCRotaryEncoder enc3 = {
{4, 5}, // 1176 3 Attack
102, // MIDI address (CC number + optional channel)
CCRotaryEncoder enc4 = {
{6, 7}, // 1176 4 Release
103, // MIDI address (CC number + optional channel)
CCRotaryEncoder enc5 = {
{8, 9}, // LA2A 1 Hi Freq
104, // MIDI address (CC number + optional channel)
CCRotaryEncoder enc6 = {
{10, 11}, // LA2A 2 Gain
105, // MIDI address (CC number + optional channel)
CCRotaryEncoder enc7 = {
{24, 25}, // LA2A 3 Peak Reduction
106, // MIDI address (CC number + optional channel)
CCRotaryEncoder enc8 = {
{26, 27}, // 2500 1 Threshold
107, // MIDI address (CC number + optional channel)
CCRotaryEncoder enc9 = {
{28, 29}, // 2500 2 Attack
108, // MIDI address (CC number + optional channel)
1, // optional multiplier if the control isn't fast enough
CCRotaryEncoder enc10 = {
{30, 31}, // 2500 3 Ratio
109, // MIDI address (CC number + optional channel)
CCRotaryEncoder enc11 = {
{32, 33}, // 2500 4 Release Position
110, // MIDI address (CC number + optional channel)
CCRotaryEncoder enc12 = {
{34, 35}, // 2500 5 Release Fine
111, // MIDI address (CC number + optional channel)
CCRotaryEncoder enc13 = {
{39, 40}, // 2500 6 Link
112, // MIDI address (CC number + optional channel)
CCRotaryEncoder enc14 = {
{21, 22}, // 2500 7 Output Gain
113, // MIDI address (CC number + optional channel)
CCRotaryEncoder enc15 = {
{17, 20}, // 2500 8 Mix
114, //
// Instantiate a program changer with 8 programs
ProgramChanger<8> programChanger {
MIDI_PC::Acoustic_Grand_Piano, // list of programs
MIDI_PC::Bright_Acoustic_Piano,
MIDI_PC::Electric_Grand_Piano,
MIDI_PC::HonkyTonk_Piano,
MIDI_PC::Electric_Piano_1,
MIDI_PC::Electric_Piano_2,
MIDI_PC::Harpsichord,
MIDI_PC::Clavi,
Channel_2, // MIDI channel to use
// Instantiate a selector that reads 8 buttons and controls the program
// changer
ManyButtonsSelector<8> programSelector {
programChanger,
{{23, 36, 37, 38, 41, 15, 14, 16}},
void isr() {
enc.update(); // Read the state of the encoders and update the positions
RelativeCCSender::setMode(relativeCCmode::MACKIE_CONTROL_RELATIVE);
Control_Surface.begin();
Wire.begin(); // Must be called before enc.begin()
Wire.setClock(800000);
enc.begin(); // Initialize the MCP23017
attachInterrupt(digitalPinToInterrupt(interrupt_pin), isr, LOW);
// No `enc.update()` here, updating the encoders happens inside of the ISR
Control_Surface.loop();
thank you very much for any help!
