Expanding on LarryD's IR remote control code:
Continuing the discussion from Press and Hold IR Remote Control Button:
#include "IRremote.h"
//LarryD
//Sketch to demonstrate using an IR hand remote to control Arduino outputs.
//The remote used here uses the NEC protocol.
//This remote sends the button code (example 0xFF629D) then a repeat code 0xFFFFFFFF
//The repeat code is re-sent as long as an IR remote button is pressed.
//The IR receiver used is the TSOP4838
/* 17 IR button remote layout http://i.imgur.com/X1KIdqI.png
< OK >
v
1 2 3
4 5 6
7 8 9
  • 0 #
const byte RECV_PIN = 7; //IR receive pin
IRrecv irrecv(RECV_PIN); //create instance of 'IRrecv'
decode_results results; //create instance of 'decode_results'
unsigned long TimerUp; //UP arrow on the remote
boolean TimerUpFlag = false;
unsigned long TimerDown; //DOWN arrow on the remote
boolean TimerDownFlag = false;
unsigned long TimerIntensity;
unsigned long TimerIncDec;
boolean intesityUpFlag = false;
boolean intesityDownFlag = false;
int brightness;
unsigned long dummy;
unsigned long * TimerPtr = &dummy; //pointer to the current timer
const byte upLED = 13; //turns on as long as the UP button is pressed
const byte downLED = 12; //turns on as long as the DOWN button is pressed
const byte leftLED = 11; //toggles on/off
const byte rightLED = 10; //toggles on/off
const byte intensityLED = 9; //a LED which can have its intensity adjusted
// s e t u p ( )
irrecv.enableIRIn(); //start receive
pinMode(upLED, OUTPUT);
pinMode(downLED, OUTPUT);
pinMode(leftLED, OUTPUT);
pinMode(rightLED, OUTPUT);
pinMode(intensityLED, OUTPUT); //this is a PWM output pin
} // E N D O F s e t u p ( )
// l o o p ( )
if (irrecv.decode(&results)) //is there IR remote button code
//Serial.println(results.value);
processButton(); //process button press
irrecv.resume(); //restart for next button press
//********************** //Turn off upLED
//if timing is enabled, is it time to stop
if (TimerUpFlag && millis() - TimerUp >= 250ul)
TimerUpFlag = false; //disable timing
TimerPtr = &dummy; //pointer to dummy timer
digitalWrite(upLED, LOW);
//********************** //Turn off downLED
if (TimerDownFlag && millis() - TimerDown >= 250ul)
TimerDownFlag = false; //disable timing
digitalWrite(downLED, LOW);
//********************** //LED intensity
//are we still within the adjustment time
if (millis() - TimerIntensity <= 300ul)
//is it time to increase/decrease the intensity
if (millis() - TimerIncDec >= 200ul)
TimerIncDec = millis();
  if (intesityUpFlag == true) //Increase
    brightness += 5;
    if (brightness > 255)
      brightness = 255;
  else if (intesityDownFlag == true) //Decrease
    brightness -= 5;
    if (brightness < 0)
      brightness = 0;
  analogWrite(intensityLED, brightness);
  //Serial.println(brightness); //debug
//stop increasing/decreasing intensity
//Other non blocking code goes here
} // E N D O F l o o p ( )
// F U N C T I O N S
// p r o c e s s B u t t o n ( )
//process IR remote button presses
void processButton()
switch (results.value)
case 0xFF629D: //UP Arrow
Serial.println("UP");
TimerPtr = &TimerUp; //point to this timer
TimerUpFlag = true; //enable timing
digitalWrite(upLED, HIGH);
TimerUp = millis();
case 0xFFA857:                                           //DOWN Arrow
    Serial.println("DOWN");
    TimerPtr = &TimerDown;  //point to this timer
    TimerDownFlag = true;   //enable timing
    digitalWrite(downLED, HIGH);
    TimerDown = millis();
case 0xFF22DD:                                           //LEFT Arrow
    Serial.println("LEFT");
    digitalWrite(leftLED, !digitalRead(leftLED));   //Toggle LED
case 0xFFC23D:                                           //RIGHT Arrow
    Serial.println("RIGHT");
    digitalWrite(rightLED, !digitalRead(rightLED)); //Toggle LED
case 0xFF42BD:                                           // * button
    Serial.println("*");
    TimerPtr = &TimerIntensity;  //point to this timer
    intesityUpFlag = true;       //enable intensity up adjustment
    TimerIntensity = millis();
case 0xFF52AD: // # button
Serial.println("#");
intesityDownFlag = true; //enable intensity down adjustment
case 0xFF02FD:
  Serial.println("OK");
case 0xFF6897:
  Serial.println("1");
case 0xFF9867:
  Serial.println("2");
case 0xFFB04F:
  Serial.println("3");
case 0xFF30CF:
  Serial.println("4");
case 0xFF18E7:
  Serial.println("5");
case 0xFF7A85:
  Serial.println("6");
case 0xFF10EF:
  Serial.println("7");
case 0xFF38C7:
  Serial.println("8");
case 0xFF5AA5:
  Serial.println("9");
case 0xFF4AB5:
  Serial.println("0");
case 0xFFFFFFFF: //Repeat code
    Serial.println("REPEAT");
    *TimerPtr = millis();       //reset the current timer
} // END switch case
} // E N D o f p r o c e s s B u t t o n ( )
// E N D O F C O D E
I'm new at this, and want to modify the code to suite my needs. I'm removing the dimmer code, and need to add additional buttons for source selection and mute. I only need momentary pulses, not steady state.
List all the receive codes for your particular NEC remote.
What exactly needs to happen when a receive code is received ?
I'm currently using a remote that came with the Arduino starter kit. Eventually, I'll be designing a custom remote with only the features/buttons I desire. I'll need to learn how to alter the code to match a purchased remote (future), or how to create code for a custom remote.
I'm in the process of gathering the button codes for the starter kit remote.
Thanks for your help, LarryD. :slight_smile:
Oh, and I did succeed in removing the PWM code, and not disturb the volume up/down and steady state features.
Most people here do not have the Arduino Starter Kit.
At least take a picture if it and show us your image of it.
Here's a pic of the starter kit:
Button wise, I need momentary pulse per button. I require on/off, volume +/-, mute, and six source buttons. The power button is on the remote, as are the volume +/-. The numbers 1 through 6 are available, so I'd probably use Func/Stop as my mute.
Here are the button codes listed left to right from the top of the remote:
FFA25D--on/off
FF629D--Vol+
FFE21D--Func/Stop
FF22DD--Left arrows
FF02FD--Play/Pause
FFC23D--Right arrows
FFE01F--Down arrow
FFA857--Vol-
FF906F--Up arrow
FF6897--0
FF9867--EQ
FFB04F--St/Rept
FF30CF--1
FF18E7--2
FF7A85--3
FF10EF--4
FF38C7--5
FF5AA5--6
FF42BD--7
FF4AB5--8
FF52AD--9
What exactly needs to happen when a receive code FFA25D is received ?
I can use a 555 timer as a latching switch to turn the sound system on/off: one pulse on, and another pulse off. So, a simple pulse out when I press the button will do.
Why not an Arduino output that goes LOW on 1st press then HIGH on 2nd press ?
Here's a pic of the remote:
Remote
That would be simpler, wouldn't it? Great suggestion, LarryD.
Here is a start.
Do you understand what needs to be done ?
//https://forum.arduino.cc/t/expanding-on-larryds-ir-remote-control-code/1014754/15
//  XXXXXXXXXX.ino
//  Version   YY/MM/DD     Comments
//  1.00      22/07/21     Running code
#define LEDon              HIGH
#define LEDoff             LOW
#define RELAYon            HIGH
#define RELAYoff           LOW
#define ENABLED            true
#define DISABLED           false
#define PUSHED             LOW
#define RELEASED           HIGH
const byte heartbeatLED  = 13;
const byte onOffLED      = 12;
//IR receive pin
//timing stuff
unsigned long heartbeatMillis;
//                                       s e t u p ( )
  pinMode(heartbeatLED, OUTPUT);
  pinMode(onOffLED, OUTPUT);
} //END of   setup()
//                                       l o o p ( )
  //is it time to toggle the heartbeatLED ?
  if (millis() - heartbeatMillis >= 500)
    //restart this TIMER
    heartbeatMillis = millis();
    //toggle the heartbeatLED
    digitalWrite(heartbeatLED, !digitalRead(heartbeatLED));
  //have we received a IR code ?
    //Serial.println(results.value, HEX);
    processButton();
} //END of   loop()
  //do what is required for this IR code
    case 0xFFA25D:                                           //ON/OFF
        Serial.println("ON/OFF");
        digitalWrite(onOffLED, !digitalRead(onOffLED));
    case 0xFF629D:                                           //Vol +
        Serial.println("Vol +");
    case 0xFFE21D:                                           //Func Stop
        Serial.println("Func Stop");
    case 0xFF22DD:                                           //Left Arrow
        Serial.println("Left Arrow");
    case 0xFF02FD:                                           //Play Pause
        Serial.println("Play Pause");
    case 0xFFC23D:                                           //Right Arrow
        Serial.println("Right Arrow");
    case 0xFFE01F:                                           //Down Arrow
        Serial.println("Down Arrow");
    case 0xFFA857:                                           //Vol -
        Serial.println("Vol -");
    case 0xFF906F:                                           //Up Arrow
        Serial.println("Up Arrow");
    case 0xFF6897:                                           //0
    case 0xFF9867:                                          //EQ
      Serial.println("EQ");
    case 0xFFB04F:                                          //St Rept
      Serial.println("St Rept");
    case 0xFF30CF:                                          //1
    case 0xFF18E7:                                          //2
    case 0xFF7A85:                                          //3
    case 0xFF10EF:                                          //4
    case 0xFF38C7:                                          //5
    case 0xFF5AA5:                                          //6
    case 0xFF42BD:                                          //7
    case 0xFF4AB5:                                          //8
    case 0xFF52AD:                                          //9
} //END of   processButton()
Edit
Added some comments.
This code is different from the original code you shared. It seems simpler. I'll explore further. Thanks, LarryD.
Is the original code still up to snuff, or is this newer code your preference?
John
One more thing: I only require a momentary pulse from the Arduino to activate my circuit. I'm adding physical N.O. momentary switches to the circuit control mix as well as the Arduino.
This is just a different version.
This version adds momentary output; as an example the Vol + (case 0xFF629D: ) button makes Arduino pin D11 go HIGH for 1 second.
You should be able to see how the momentary operation is accomplished.
//  XXXXXXXXXX.ino
#define LEDon              HIGH
#define LEDoff             LOW
#define RELAYon            LOW
#define RELAYoff           HIGH
#define PUSHED             LOW
const byte pin11LED                   = 11;
//IR receive pin
boolean pin11_TimerFlag               = DISABLED;
//timing stuff
unsigned long pin11_Millis;
const unsigned long pin11_OnInterval  = 1000ul;
//                                       s e t u p ( )
  //start IR receiver
  digitalWrite(onOffLED, LEDoff);
  pinMode(pin11LED, OUTPUT);
  digitalWrite(pin11LED, LEDoff);
} //END of   setup()
//                                       l o o p ( )
  //have we received an IR code ?
    processButton();
    irrecv.resume();
  //when this TIMER is enabled, is it time to turn OFF the LED on pin 11?
  if (pin11_TimerFlag == ENABLED && millis() - pin11_Millis >= pin11_OnInterval)
    //this TIMER has expired, disable it for now
} //END of   loop()
        //when we 'are not' currently timing
        if (pin11_TimerFlag == DISABLED)
          //enable the TIMER
          pin11_TimerFlag = ENABLED;
          //reset the TIMER
          pin11_Millis = millis();
          digitalWrite(pin11LED, LEDon);
    case 0xFF6897:                                           //0
    case 0xFF9867:                                          //EQ
    case 0xFF30CF:                                          //1
    case 0xFF18E7:                                          //2
    case 0xFF7A85:                                          //3
    case 0xFF10EF:                                          //4
    case 0xFF38C7:                                          //5
    case 0xFF5AA5:                                          //6
    case 0xFF42BD:                                          //7
    case 0xFF4AB5:                                          //8
    case 0xFF52AD:                                          //9
  } //END    switch . . . case
