Hello! I'm doing a project in Arduino, basically is programming a MiniCar from Elegoo. I found this programm in the Elegoo page (for the programming of the MiniCar Robot) and just did a copy-paste to see if it works. Now this message pops up, and i have checked several times (and with a results page) and think there is every bracket. I also installed a driver to detect the port. The problem is that i tried a different board (an Arduino Nano from Arduino) and it doesn't upload, it's stuck in uploading.
I would really appreciate some help.
Thank you!
PROGRAMM:
class L293
public:
int left_1_pin;
int left_2_pin;
int right_1_pin;
int right_2_pin;
int enable_left_pin;
int enable_right_pin;
int car_speed = 0;
int turn_speed = 0;
uint16_t left_speed = 0;
uint16_t right_speed = 0;
enum RUN_STATUE
STOP,
BACK,
FORWARD,
LEFT,
RIGHT
} run_statue = STOP;
void setup (int left1pin, int left2pin, int right1pin, int right2pin, int enableleftpin, int enablerightpin)
left_1_pin = left1pin;
left_2_pin = left2pin;
right_1_pin = right1pin;
right_2_pin = right2pin;
enable_left_pin = enableleftpin;
enable_right_pin = enablerightpin;
pinMode(left_1_pin, OUTPUT);
pinMode(left_2_pin, OUTPUT);
pinMode(right_1_pin, OUTPUT);
pinMode(right_2_pin, OUTPUT);
pinMode(enable_left_pin, OUTPUT);
pinMode(enable_right_pin, OUTPUT);
stop();
void leftFront(int leftspeed)
analogWrite(enable_left_pin, leftspeed);
digitalWrite(left_1_pin, HIGH);
digitalWrite(left_2_pin, LOW);
void leftBack(int leftspeed)
digitalWrite(left_1_pin, LOW);
digitalWrite(left_2_pin, HIGH);
void leftStop()
analogWrite(enable_left_pin, 0);
void rightFront(int rightspeed)
analogWrite(enable_right_pin, rightspeed);
digitalWrite(right_1_pin, LOW);
digitalWrite(right_2_pin, HIGH);
void rightBack(int rightspeed)
digitalWrite(right_1_pin, HIGH);
digitalWrite(right_2_pin, LOW);
void rightStop()
analogWrite(enable_right_pin, 0);
void forward(int speed)
run_statue = FORWARD;
left_speed = speed;
right_speed = speed;
leftFront(speed);
rightFront(speed);
void back(int speed)
run_statue = BACK;
left_speed = speed;
leftBack(speed);
rightBack(speed);
void left(int speed)
run_statue = LEFT;
left_speed = speed;
leftBack(speed);
rightFront(speed);
void right(int speed)
run_statue = RIGHT;
left_speed = speed;
leftFront(speed);
rightBack(speed);
void stop()
run_statue = STOP;
left_speed = 0;
right_speed = 0;
car_speed = 0;
turn_speed = 0;
leftStop();
rightStop();
void left2(int speed)
run_statue = LEFT;
left_speed = speed;
leftFront(speed - 100);
rightFront(speed);
void right2(int speed)
run_statue = RIGHT;
left_speed = speed;
leftFront(speed);
rightFront(speed - 100);
PROBLEM:
Arduino:1.8.13 (Windows 10), Tarjeta:"Arduino Nano, ATmega328P (Old Bootloader)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Nina\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Nina\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Nina\OneDrive\Documentos\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=04D9_B534 -ide-version=10813 -build-path C:\Users\Nina\AppData\Local\Temp\arduino_build_524955 -warnings=none -build-cache C:\Users\Nina\AppData\Local\Temp\arduino_cache_529741 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Nina\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.arduinoOTA-1.1.1.path=C:\Users\Nina\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avrdude.path=C:\Users\Nina\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.avrdude-6.3.0-arduino9.path=C:\Users\Nina\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.avr-gcc.path=C:\Users\Nina\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.avr-gcc-4.9.2-atmel3.5.4-arduino2.path=C:\Users\Nina\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -verbose C:\Users\Nina\OneDrive\Documentos\Arduino\TdR\prova\prova.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Nina\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Nina\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Nina\OneDrive\Documentos\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=04D9_B534 -ide-version=10813 -build-path C:\Users\Nina\AppData\Local\Temp\arduino_build_524955 -warnings=none -build-cache C:\Users\Nina\AppData\Local\Temp\arduino_cache_529741 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Nina\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.arduinoOTA-1.1.1.path=C:\Users\Nina\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avrdude.path=C:\Users\Nina\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.avrdude-6.3.0-arduino9.path=C:\Users\Nina\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.avr-gcc.path=C:\Users\Nina\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.avr-gcc-4.9.2-atmel3.5.4-arduino2.path=C:\Users\Nina\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -verbose C:\Users\Nina\OneDrive\Documentos\Arduino\TdR\prova\prova.ino
Using board 'nano' from platform in folder: C:\Users\Nina\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21
Using core 'arduino' from platform in folder: C:\Users\Nina\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21
Detecting libraries used...
"C:\Users\Nina\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\Nina\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino" "-IC:\Users\Nina\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\variants\eightanaloginputs" "C:\Users\Nina\AppData\Local\Temp\arduino_build_524955\sketch\prova.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"C:\Users\Nina\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\Nina\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino" "-IC:\Users\Nina\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\variants\eightanaloginputs" "C:\Users\Nina\AppData\Local\Temp\arduino_build_524955\sketch\prova.ino.cpp" -o "C:\Users\Nina\AppData\Local\Temp\arduino_build_524955\preproc\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Nina\AppData\Local\Temp\arduino_build_524955\preproc\ctags_target_for_gcc_minus_e.cpp"
Compilando programa...
"C:\Users\Nina\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\Nina\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino" "-IC:\Users\Nina\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\variants\eightanaloginputs" "C:\Users\Nina\AppData\Local\Temp\arduino_build_524955\sketch\prova.ino.cpp" -o "C:\Users\Nina\AppData\Local\Temp\arduino_build_524955\sketch\prova.ino.cpp.o"
prova:146:3: error: expected '}' at end of input
prova:146:3: error: expected unqualified-id at end of input
exit status 1
