expected } at end of input
I can't seem to get my program to be right, it keeps popping up with the message "expected } at end of input", I'm confused because I already have a } as the last line. My entire code is below-
#include <LiquidCrystal.h>
LiquidCrystal lcd(12,11,5,4,3,2);
lcd.begin(16, 2);
lcd.clear();
lcd.print("hello, world!");
void loop();
lcd.setCursor(0,1);
lcd.print(millis()/100);
Serial.print("Temp in deg C = ");
Serial.println(analogRead(A0)*0.503-53);
delay(100);
But you also have too many { for setup()
Hello.
Please use code tags. Please post the exact error that displays. Although this is a simple problem, later on you may have a more complex problem and if you don't post using the guidelines you'll find no one wants to help.
example of code tag
{    // <<<<<<<<< THAT IS YOUR PROBLEM
  lcd.begin(16, 2);
  lcd.clear();
void loop();
  lcd.setCursor(0,1);
  delay(100);
void loop();
Why does one function declaration have a ; (incorrectly) while the other does not?
