Expected '(' before 'digitalRead'
Hello, so basically im completely new to arduino and programming overall. I tried to make simple traffic light using arduino. I ran in to issue with function 'if' and 'digitalwrite'. The code is not complete yet this is all i have. Thanks in advance
int button = 0;
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, INPUT);
 if digitalRead (5, HIGH); {
 int button = random(10, 5000);
  delay(button);
 digitalWrite(4, HIGH);
  delay(50);
 digitalWrite(4, LOW);
 digitalWrite(3, HIGH);
  delay(50);
 digitalWrite(3, LOW);
This has two problems:
You need parentheses around the if clause, and you need to eliminate the null statement following the if by eliminating the semicolon:
 if (digitalRead (5, HIGH)) {
if requires () around the test expression
also removed the ; which would terminate the if
also you redefine button inside the {} which will create a local variable
Oops -- three problems.
Try:
 if (digitalRead (5) == HIGH)
