expected '}' before '{' token , how to solves this?? is there any solution??
const int tombol_mtr_kanan_1 = 11;
const int tombol_mtr_kiri_1 = 10;
const int tombol_break_1 = 9;
const int tombol_mtr_kanan_2 = 8;
const int tombol_mtr_kiri_2 = 7;
const int tombol_break_2 = 6;
const int IN1Pin = 5;
const int IN2Pin = 4;
const int IN3Pin = 3;
const int IN4Pin = 2;
pinMode(tombol_mtr_kanan_1, INPUT_PULLUP);
pinMode(tombol_mtr_kiri_1, INPUT_PULLUP);
pinMode(tombol_break_1, INPUT_PULLUP);
pinMode(tombol_mtr_kanan_2, INPUT_PULLUP);
pinMode(tombol_mtr_kiri_2, INPUT_PULLUP);
pinMode(tombol_break_2, INPUT_PULLUP);
pinMode(IN1Pin, OUTPUT);
pinMode(IN2Pin, OUTPUT);
pinMode(IN3Pin, OUTPUT);
pinMode(IN4Pin, OUTPUT);
if (digitalRead(tombol_mtr_kanan_1)==LOW){
digitalWrite(IN1Pin,HIGH);
digitalWrite(IN2Pin,LOW);
if (digitalRead(tombol_mtr_kiri_1)==LOW)
digitalWrite(IN1Pin,LOW);
digitalWrite(IN2Pin,HIGH);
if(digitalRead(tombol_break_1==LOW)
if (digitalRead(tombol_mtr_kanan_2)==LOW){
digitalWrite(IN3Pin,HIGH);
digitalWrite(IN4Pin,LOW);
if (digitalRead(tombol_mtr_kiri_2)==LOW){
digitalWrite(IN3Pin,LOW);
digitalWrite(IN4Pin,HIGH);
if(digitalRead(tombol_break_2==LOW){
you have missing ) and extra } in your code
next time use code tags when posting your sketch
BTW, here is your sketch that 'compiles'
 if(digitalRead(tombol_break_1)==LOW)
if(digitalRead(tombol_break_2)==LOW){
A quick tip. In the IDE put the cursor just after an opening brace. The IDE’s editor will then put a box round the matching closing brace. This is great for finding out if you have missed or got too many closing braces.
It is a shame that the facility to double click on a brace or bracket and have the whole associated code block highlighted was removed a while ago. Highlighting the block eliminated the need to even search for the boxed matching brace
I still think that the compiler could come up with more clear error msgs when a brace is missing somewhere, it would save us all a lot of time.
