Received the "expected constructor, destructor, or type conversion before '=' token error" when trying to compile an example sketch from adafruit for their neopixel ring.
int topLED = 1;
int hours = 1;
int minutes = 0;
int seconds = 0;
int buttonPin = 1;
int buttonState;
int lastButtonState = HIGH;
long buttonHoldTime = 0;
long buttonHoldDelay = 2500;
int lastCombined = 0;
strip = Adafruit_NeoPixel(16, 6, NEO_GRB + NEO_KHZ800);
pinMode(buttonPin, INPUT);
digitalWrite(buttonPin, HIGH);
strip.begin();
strip.show(); // Initialize all pixels to 'off'
// read the state of the switch into a local variable:
int buttonState = digitalRead(buttonPin);
if (buttonState == LOW) {
buttonCheck();
lastButtonState = buttonState;
for (hours = 1; hours < 13; hours++) {
for (minutes = 1; minutes < 60; minutes++) {
for (seconds = 1; seconds < 60; seconds++) {
Serial.print(hours);
Serial.print(":");
Serial.print(minutes);
Serial.print(":");
Serial.print(seconds);
Serial.println(".");
float gpsMin = (minutes + (seconds/60.0));
unsigned int ledMin = 0;
int minTemp = 0;
if (gpsMin <= 1.875) minTemp = topLED;
if ((gpsMin > 1.875) && (gpsMin <= 5.625)) minTemp = topLED - 1;
if ((gpsMin > 5.625) && (gpsMin <= 9.375)) minTemp = topLED - 2;
if ((gpsMin > 9.375) && (gpsMin <= 13.125)) minTemp = topLED - 3;
if ((gpsMin > 13.125) && (gpsMin <= 16.875)) minTemp = topLED - 4;
if ((gpsMin > 16.875) && (gpsMin <= 20.625)) minTemp = topLED - 5;
if ((gpsMin > 20.625) && (gpsMin <= 24.375)) minTemp = topLED - 6;
if ((gpsMin > 24.375) && (gpsMin <= 28.125)) minTemp = topLED - 7;
if ((gpsMin > 28.125) && (gpsMin <= 31.875)) minTemp = topLED - 8;
if ((gpsMin > 31.875) && (gpsMin <= 35.625)) minTemp = topLED - 9;
if ((gpsMin > 35.625) && (gpsMin <= 39.375)) minTemp = topLED - 10;
if ((gpsMin > 39.375) && (gpsMin <= 43.125)) minTemp = topLED - 11;
if ((gpsMin > 43.125) && (gpsMin <= 46.875)) minTemp = topLED - 12;
if ((gpsMin > 46.875) && (gpsMin <= 50.625)) minTemp = topLED - 13;
if ((gpsMin > 50.625) && (gpsMin <= 54.375)) minTemp = topLED - 14;
if ((gpsMin > 54.375) && (gpsMin <= 58.125)) minTemp = topLED - 15;
if (gpsMin > 58.125) minTemp = topLED - 16;
if (minTemp < 0) {
ledMin = minTemp + 16;
ledMin = minTemp;
float gpsHour = (hours + (minutes/60.0));
if (gpsHour > 12) { gpsHour = gpsHour - 12; }
unsigned int ledHour = 0;
int hourTemp = 0;
if (gpsHour <= 0.375) hourTemp = topLED;
if ((gpsHour > 0.375) && (gpsHour <= 1.125)) hourTemp = topLED - 1;
if ((gpsHour > 1.125) && (gpsHour <= 1.875)) hourTemp = topLED - 2;
if ((gpsHour > 1.875) && (gpsHour <= 2.625)) hourTemp = topLED - 3;
if ((gpsHour > 2.625) && (gpsHour <= 3.375)) hourTemp = topLED - 4;
if ((gpsHour > 3.375) && (gpsHour <= 4.125)) hourTemp = topLED - 5;
if ((gpsHour > 4.125) && (gpsHour <= 4.875)) hourTemp = topLED - 6;
if ((gpsHour > 4.875) && (gpsHour <= 5.625)) hourTemp = topLED - 7;
if ((gpsHour > 5.625) && (gpsHour <= 6.375)) hourTemp = topLED - 8;
if ((gpsHour > 6.375) && (gpsHour <= 7.125)) hourTemp = topLED - 9;
if ((gpsHour > 7.125) && (gpsHour <= 7.875)) hourTemp = topLED - 10;
if ((gpsHour > 7.875) && (gpsHour <= 8.625)) hourTemp = topLED - 11;
if ((gpsHour > 8.625) && (gpsHour <= 9.375)) hourTemp = topLED - 12;
if ((gpsHour > 9.375) && (gpsHour <= 10.125)) hourTemp = topLED - 13;
if ((gpsHour > 10.125) && (gpsHour <= 10.875)) hourTemp = topLED - 14;
if ((gpsHour > 10.875) && (gpsHour <= 11.625)) hourTemp = topLED - 15;
if (gpsHour > 11.625) hourTemp = topLED - 16;
if (hourTemp < 0) {
ledHour = hourTemp + 16;
ledHour = hourTemp;
if ((ledHour == ledMin) && (lastCombined == 0)) {
strip.setPixelColor(lastHour, strip.Color(0, 0, 0));
strip.setPixelColor(lastMin, strip.Color(0, 0, 0));
strip.setPixelColor(ledHour, strip.Color(255, 0, 255));
strip.show();
lastCombined = 1;
lastHour = ledHour;
lastMin = ledMin;
if (lastHour != ledHour) {
strip.setPixelColor(ledHour, strip.Color(255, 50, 0));
strip.show();
lastHour = ledHour;
if (lastMin != ledMin) {
strip.setPixelColor(ledMin, strip.Color(200, 200, 0));
if (lastCombined == 1) {
strip.setPixelColor(ledHour, strip.Color(255, 0, 0));
lastCombined = 0;
strip.show();
lastMin = ledMin;
// if millis() or timer wraps around, we'll just reset it
if (startupTimer > millis()) startupTimer = millis();
// approximately every 10 seconds or so, update time
if (millis() - startupTimer > 200) {
startupTimer = millis(); // reset the timer
if (startLED == 16) {
startLED = 0;
strip.setPixelColor(startLEDlast, strip.Color(0, 0, 0));
strip.setPixelColor(startLED, strip.Color(0, 255, 0));
strip.show();
startLEDlast = startLED;
startLED++;
//delay(200);
delay(20);
void buttonCheck() {
menuTime = millis();
if (buttonState == LOW && lastButtonState == HIGH) {
buttonHoldTime = millis();
if (buttonState == LOW && lastButtonState == LOW) {
if ((millis() - buttonHoldTime) > buttonHoldDelay) {
if(mode == 2) {
mode = 0;
lastMin = 16;
lastHour = 16;
colorWipe(strip.Color(0, 0, 0), 20);
mode = mode + 1;
The error is for the following code
Example sketch from adafruit is as follows
#define PIN 6
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
strip.begin();
// Some example procedures showing how to display to the pixels:
colorWipe(strip.Color(255, 0, 0), 50); // Red
colorWipe(strip.Color(0, 255, 0), 50); // Green
colorWipe(strip.Color(0, 0, 255), 50); // Blue
rainbow(20);
rainbowCycle(20);
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
delay(wait);
void rainbow(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256; j++) {
for(i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel((i+j) & 255));
strip.show();
delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
for(i=0; i< strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
strip.show();
delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if(WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
All help is greatly appreciated.
