Expected constructor, destructor, or type conversion before ';' token. Help
Can anyone help me on this error?
#include <LedControl.h>
  Render();
//Define The Snake as a Struct
typedef struct Snake Snake;
struct Snake{
  int head[2];     // the (row, column) of the snake head
  int body[40][2]; //An array that contains the (row, column) coordinates
  int len;         //The length of the snake
  int dir[2];      //A direction to move the snake along
//Define The Apple as a Struct
typedef struct Apple Apple;
struct Apple{
  int rPos; //The row index of the apple
  int cPos; //The column index of the apple
//MAX72XX led Matrix
const int DIN =12;
const int CS =11;
const int CLK = 10;
LedControl lc = LedControl(DIN, CLK, CS,1);
const int varXPin = A3;//X Value  from Joystick
const int varYPin = A4;//Y Value from Joystick
byte pic[8] = {0,0,0,0,0,0,0,0};//The 8 rows of the LED Matrix
Snake snake = {{1,5},{{0,5}, {1,5}}, 2, {1,0}};//Initialize a snake object
Apple apple = {(int)random(0,8),(int)random(0,8)};//Initialize an apple object
//Variables To Handle The Game Time
float oldTime = 0;
float timer = 0;
float updateRate = 3;
int i,j;//Counters
#define NOTE_B0  31
#define NOTE_C1  33
#define NOTE_CS1 35
#define NOTE_D1  37
#define NOTE_DS1 39
#define NOTE_E1  41
#define NOTE_F1  44
#define NOTE_FS1 46
#define NOTE_G1  49
#define NOTE_GS1 52
#define NOTE_A1  55
#define NOTE_AS1 58
#define NOTE_B1  62
#define NOTE_C2  65
#define NOTE_CS2 69
#define NOTE_D2  73
#define NOTE_DS2 78
#define NOTE_E2  82
#define NOTE_F2  87
#define NOTE_FS2 93
#define NOTE_G2  98
#define NOTE_GS2 104
#define NOTE_A2  110
#define NOTE_AS2 117
#define NOTE_B2  123
#define NOTE_C3  131
#define NOTE_CS3 139
#define NOTE_D3  147
#define NOTE_DS3 156
#define NOTE_E3  165
#define NOTE_F3  175
#define NOTE_FS3 185
#define NOTE_G3  196
#define NOTE_GS3 208
#define NOTE_A3  220
#define NOTE_AS3 233
#define NOTE_B3  247
#define NOTE_C4  262
#define NOTE_CS4 277
#define NOTE_D4  294
#define NOTE_DS4 311
#define NOTE_E4  330
#define NOTE_F4  349
#define NOTE_FS4 370
#define NOTE_G4  392
#define NOTE_GS4 415
#define NOTE_A4  440
#define NOTE_AS4 466
#define NOTE_B4  494
#define NOTE_C5  523
#define NOTE_CS5 554
#define NOTE_D5  587
#define NOTE_DS5 622
#define NOTE_E5  659
#define NOTE_F5  698
#define NOTE_FS5 740
#define NOTE_G5  784
#define NOTE_GS5 831
#define NOTE_A5  880
#define NOTE_AS5 932
#define NOTE_B5  988
#define NOTE_C6  1047
#define NOTE_CS6 1109
#define NOTE_D6  1175
#define NOTE_DS6 1245
#define NOTE_E6  1319
#define NOTE_F6  1397
#define NOTE_FS6 1480
#define NOTE_G6  1568
#define NOTE_GS6 1661
#define NOTE_A6  1760
#define NOTE_AS6 1865
#define NOTE_B6  1976
#define NOTE_C7  2093
#define NOTE_CS7 2217
#define NOTE_D7  2349
#define NOTE_DS7 2489
#define NOTE_E7  2637
#define NOTE_F7  2794
#define NOTE_FS7 2960
#define NOTE_G7  3136
#define NOTE_GS7 3322
#define NOTE_A7  3520
#define NOTE_AS7 3729
#define NOTE_B7  3951
#define NOTE_C8  4186
#define NOTE_CS8 4435
#define NOTE_D8  4699
#define NOTE_DS8 4978
#define melodyPin 3
//Mario main theme melody
int melody[] = {
  NOTE_E7, NOTE_E7, 0, NOTE_E7,
  0, NOTE_C7, NOTE_E7, 0,
  NOTE_G7, 0, 0,  0,
  NOTE_G6, 0, 0, 0,
  NOTE_C7, 0, 0, NOTE_G6,
  0, 0, NOTE_E6, 0,
  0, NOTE_A6, 0, NOTE_B6,
  0, NOTE_AS6, NOTE_A6, 0,
  NOTE_G6, NOTE_E7, NOTE_G7,
  NOTE_A7, 0, NOTE_F7, NOTE_G7,
  0, NOTE_E7, 0, NOTE_C7,
  NOTE_D7, NOTE_B6, 0, 0,
  0, 0, NOTE_E6, 0,
//Mario main them tempo
int tempo[] = {
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
  9, 9, 9,
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
  9, 9, 9,
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
//Underworld melody
int underworld_melody[] = {
  NOTE_C4, NOTE_C5, NOTE_A3, NOTE_A4,
  NOTE_AS3, NOTE_AS4, 0,
  0,
  0,
  NOTE_F3, NOTE_F4, NOTE_D3, NOTE_D4,
  NOTE_DS3, NOTE_DS4, 0,
  0,
  0, NOTE_DS4, NOTE_CS4, NOTE_D4,
  NOTE_CS4, NOTE_DS4,
  NOTE_DS4, NOTE_GS3,
  NOTE_G3, NOTE_CS4,
  NOTE_C4, NOTE_FS4, NOTE_F4, NOTE_E3, NOTE_AS4, NOTE_A4,
  NOTE_GS4, NOTE_DS4, NOTE_B3,
  NOTE_AS3, NOTE_A3, NOTE_GS3,
  0, 0, 0
//Underwolrd tempo
int underworld_tempo[] = {
  12, 12, 12, 12,
  12, 12, 6,
  3,
  12, 12, 12, 12,
  12, 12, 6,
  3,
  12, 12, 12, 12,
  12, 12, 6,
  3,
  12, 12, 12, 12,
  12, 12, 6,
  6, 18, 18, 18,
  6, 6,
  6, 6,
  6, 6,
  18, 18, 18, 18, 18, 18,
  10, 10, 10,
  10, 10, 10,
  3, 3, 3
void setup(void)
  lc.shutdown(0,false);
  /* Set the brightness to a medium values */
  lc.setIntensity(0,8);
  /* and clear the display */
  lc.clearDisplay(0);
  pinMode(3, OUTPUT);//buzzer
  pinMode(13, OUTPUT);//led indicator when singing a note
  //Set Joystick Pins as INPUTs
  pinMode(varXPin, INPUT);
  pinMode(varYPin, INPUT);
  float deltaTime = calculateDeltaTime();
  timer += deltaTime;
  //Check For Inputs
  int xVal = analogRead(varXPin);
  int yVal = analogRead(varYPin);
  if(xVal<100 && snake.dir[1]==0){
    snake.dir[0] = 0;
    snake.dir[1] = -1;
  }else if(xVal >920 && snake.dir[1]==0){
    snake.dir[0] = 0;
    snake.dir[1] = 1;
  }else if(yVal<100 && snake.dir[0]==0){
    snake.dir[0] = -1;
    snake.dir[1] = 0;
  }else if(yVal >920 && snake.dir[0]==0){
    snake.dir[0] = 1;
    snake.dir[1] = 0;
  //Update
  if(timer > 1000/updateRate){
    timer = 0;
    Update();
//Render
float calculateDeltaTime(){
  float currentTime = millis();
  float dt = currentTime - oldTime;
  oldTime = currentTime;
  return dt;
void reset(){
  for(int j=0;j<8;j++){
    pic[j] = 0;
void Update(){
  reset();//Reset (Clear) the 8x8 LED matrix
  int newHead[2] = {snake.head[0]+snake.dir[0], snake.head[1]+snake.dir[1]};
  //Handle Borders
  if(newHead[0]==8){
    newHead[0]=0;
  }else if(newHead[0]==-1){
    newHead[0] = 7;
  }else if(newHead[1]==8){
    newHead[1]=0;
  }else if(newHead[1]==-1){
    newHead[1]=7;
  for(j=0;j<snake.len;j++){
  }if(snake.body[j][0] == newHead[0] && snake.body[j][1] == newHead[1]){
    snake = {{1,5},{{0,5}, {1,5}}, 2, {1,0}};//Reinitialize the snake object
    apple = {(int)random(0,8),(int)random(0,8)};//Reinitialize an apple object
    return;
if(newHead[0] == apple.rPos && newHead[1] ==apple.cPos){
  snake.len = snake.len+1;
    apple.rPos = (int)random(0,8);
    apple.cPos = (int)random(0,8);
  }else{
    removeFirst();//Shifting the array to the left
  snake.body[snake.len-1][0]= newHead[0];
  snake.body[snake.len-1][1]= newHead[1];
  snake.head[0] = newHead[0];
  snake.head[1] = newHead[1];
    pic[snake.body[j][0]] |= 128 >> snake.body[j][1];
  pic[apple.rPos] |= 128 >> apple.cPos;
void Render(){
  for(i=0;i<8;i++){
    lc.setRow(0,i,pic[i]);
void removeFirst(){
  for(j=1;j<snake.len;j++){
    snake.body[j-1][0] = snake.body[j][0];
    snake.body[j-1][1] = snake.body[j][1];
  //sing the tunes
  sing(1);
  sing(1);
  sing(2);
int song = 0;
void sing(int s) {
  // iterate over the notes of the melody:
  song = s;
  if (song == 2) {
    Serial.println(" 'Underworld Theme'");
    int size = sizeof(underworld_melody) / sizeof(int);
    for (int thisNote = 0; thisNote < size; thisNote++) {
      // to calculate the note duration, take one second
      // divided by the note type.
      //e.g. quarter note = 1000 / 4, eighth note = 1000/8, etc.
      int noteDuration = 1000 / underworld_tempo[thisNote];
      buzz(melodyPin, underworld_melody[thisNote], noteDuration);
      // to distinguish the notes, set a minimum time between them.
      // the note's duration + 30% seems to work well:
      int pauseBetweenNotes = noteDuration * 1.30;
      delay(pauseBetweenNotes);
      // stop the tone playing:
      buzz(melodyPin, 0, noteDuration);
    Serial.println(" 'Mario Theme'");
    int size = sizeof(melody) / sizeof(int);
      int noteDuration = 1000 / tempo[thisNote];
      buzz(melodyPin, melody[thisNote], noteDuration);
void buzz(int targetPin, long frequency, long length) {
  digitalWrite(13, HIGH);
  long delayValue = 1000000 / frequency / 2; // calculate the delay value between transitions
  //// 1 second's worth of microseconds, divided by the frequency, then split in half since
  //// there are two phases to each cycle
  long numCycles = frequency * length / 1000; // calculate the number of cycles for proper timing
  //// multiply frequency, which is really cycles per second, by the number of seconds to
  //// get the total number of cycles to produce
  for (long i = 0; i < numCycles; i++) { // for the calculated length of time...
    digitalWrite(targetPin, HIGH); // write the buzzer pin high to push out the diaphram
    delayMicroseconds(delayValue); // wait for the calculated delay value
    digitalWrite(targetPin, LOW); // write the buzzer pin low to pull back the diaphram
    delayMicroseconds(delayValue); // wait again or the calculated delay value
  digitalWrite(13, LOW);
This code is a bit of a jumbled up mess... there a re number of pieces of code that look like they have been cut & pasted into the wrong place.
There is random code sitting in the middle of no where...
This for loop does nothing...
Can you post the specific error text you're trying to address - we can approach them one at a time.
Alright
Arduino: 1.8.19 (Mac OS X), Board: "Arduino Uno"
sketch_nov03b:2:11: error: expected constructor, destructor, or type conversion before ';' token
   Render();
sketch_nov03b:315:1: error: expected unqualified-id before 'if'
sketch_nov03b:319:4: error: expected unqualified-id before 'else'
   }else{
sketch_nov03b:323:3: error: 'snake' does not name a type
sketch_nov03b:324:3: error: 'snake' does not name a type
sketch_nov03b:326:3: error: 'snake' does not name a type
sketch_nov03b:327:3: error: 'snake' does not name a type
sketch_nov03b:329:3: error: expected unqualified-id before 'for'
sketch_nov03b:329:11: error: 'j' does not name a type
sketch_nov03b:329:23: error: 'j' does not name a type
sketch_nov03b:332:3: error: 'pic' does not name a type
sketch_nov03b:334:1: error: expected declaration before '}' token
exit status 1
option enabled in File -> Preferences.
I have been trying to combine 2 sketches, one for a 8x8 matrix game, and a song sketch
I'll show you the sketches seperately, 1st one is Matrix Game Sketch. 2nd one is the sketch for piezo buzzer
struct Snake{
struct Apple{
const int DIN =12;
const int CS =11;
const int CLK = 10;
float oldTime = 0;
float timer = 0;
int i,j;//Counters
   The MAX72XX is in power-saving mode on startup,
   we have to do a wakeup call
  lc.clearDisplay(0);
  timer += deltaTime;
  //Check For Inputs
    snake.dir[0] = 0;
    snake.dir[1] = -1;
    snake.dir[0] = 0;
    snake.dir[1] = 1;
    snake.dir[0] = -1;
    snake.dir[1] = 0;
    snake.dir[0] = 1;
    snake.dir[1] = 0;
  //Update
    timer = 0;
    Update();
  //Render
  Render();
  return dt;
void reset(){
    pic[j] = 0;
void Update(){
  //Handle Borders
  if(newHead[0]==8){
    newHead[0]=0;
    newHead[0] = 7;
    newHead[1]=0;
    newHead[1]=7;
  //Check If The Snake hits itself
      //Pause the game for 1 sec then Reset it
      return;
  //Check if The snake ate the apple
  }else{
  //Update the pic Array to Display(snake and apple)
void Render(){
   for(i=0;i<8;i++){
void removeFirst(){
#define NOTE_B0  31
#define NOTE_C1  33
#define NOTE_CS1 35
#define NOTE_D1  37
#define NOTE_DS1 39
#define NOTE_E1  41
#define NOTE_F1  44
#define NOTE_FS1 46
#define NOTE_G1  49
#define NOTE_GS1 52
#define NOTE_A1  55
#define NOTE_AS1 58
#define NOTE_B1  62
#define NOTE_C2  65
#define NOTE_CS2 69
#define NOTE_D2  73
#define NOTE_DS2 78
#define NOTE_E2  82
#define NOTE_F2  87
#define NOTE_FS2 93
#define NOTE_G2  98
#define NOTE_A2  110
#define NOTE_B2  123
#define NOTE_C3  131
#define NOTE_D3  147
#define NOTE_E3  165
#define NOTE_F3  175
#define NOTE_G3  196
#define NOTE_A3  220
#define NOTE_B3  247
#define NOTE_C4  262
#define NOTE_D4  294
#define NOTE_E4  330
#define NOTE_F4  349
#define NOTE_G4  392
#define NOTE_A4  440
#define NOTE_B4  494
#define NOTE_C5  523
#define NOTE_D5  587
#define NOTE_E5  659
#define NOTE_F5  698
#define NOTE_G5  784
#define NOTE_A5  880
#define NOTE_B5  988
#define melodyPin 3
int melody[] = {
  NOTE_G7, 0, 0,  0,
  NOTE_G6, 0, 0, 0,
  0, 0, NOTE_E6, 0,
  0, 0, NOTE_E6, 0,
int tempo[] = {
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
  9, 9, 9,
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
  9, 9, 9,
  12, 12, 12, 12,
  12, 12, 12, 12,
  12, 12, 12, 12,
//Underworld melody
  0,
  0,
  0,
  NOTE_CS4, NOTE_DS4,
  NOTE_DS4, NOTE_GS3,
  NOTE_G3, NOTE_CS4,
  0, 0, 0
//Underwolrd tempo
  12, 12, 12, 12,
  12, 12, 6,
  3,
  12, 12, 12, 12,
  12, 12, 6,
  3,
  12, 12, 12, 12,
  12, 12, 6,
  3,
  12, 12, 12, 12,
  12, 12, 6,
  6, 18, 18, 18,
  6, 6,
  6, 6,
  6, 6,
  10, 10, 10,
  10, 10, 10,
  3, 3, 3
void setup(void)
  //sing the tunes
  sing(1);
  sing(1);
  sing(2);
int song = 0;
void sing(int s) {
  song = s;
  if (song == 2) {
