Expected constructor, destructor, or type conversion before '(' token | i need some help
#include <MQ2.h>
//change this with the pin that you use
int pin = A0;
float lpg, co, smoke;
pinMode(6, OUTPUT);
MQ2 mq2(pin);
void setup(){
  // calibrate the device
  mq2.begin();
void loop(){
   * read the values from the sensor, it returns
   * an array which contains 3 values.
   * 0 : LPG in ppm
   * 1 : CO in ppm
   * 2 : SMOKE in ppm
  float* values= mq2.read(true); //set it false if you don't want to print the values to the Serial
  // lpg = values[0];
  lpg = mq2.readLPG();
  // co = values[1];
  co = mq2.readCO();
  // smoke = values[2];
  smoke = mq2.readSmoke();
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Placa:"Arduino Uno"
sketch_sep29a:6:8: error: expected constructor, destructor, or type conversion before '(' token
pinMode(6, OUTPUT);
exit status 1
that goes into setup().
