expected constructor, destructor, or type conversion before '(' token
I’m having trouble with project 06 in the Genuino project.
Here is my code:
int sensorValue;
int sensorLow = 1023;
int sensorHigh = 0;
pinMode (ledPin, OUTPUT)
digitalWrite(ledPin, HIGH);
const int ledPin = 13;
while (millis() < 5000) {
sensorValue = analogRead(AO);
if (sensorValue > sensorHigh) {
sensorValue = sensorHigh;
if (sensorValue < sensorLow) {
sensorValue = sensorLow;
digitalWrite(ledPin, LOW);
int pitch =
map(sensorValue, sensorLow, sensorHigh, 50, 4000);
tone(8, pitch, 20);
delay(10);
I’ve moved some parts because other wise it would not communicate properly.
You have a number of statements that are not inside a function.
And in future, please use code tags when posting code
type
** **[code]** **
paste your code after that
type
** **[/code]** **
So it looks like
int sensorValue;
int sensorHigh = 0;
  int pitch =
  tone(8, pitch, 20);
  delay(10);
And if you place your mouse in the output window and scroll up, you will see a lot more info. Below all the orange lines as a result of the compile.
sketch_jul02a:6: error: expected constructor, destructor, or type conversion before '(' token
sketch_jul02a:10: error: expected unqualified-id before 'while'
exit status 1
You can’t put a pinMode() call (or any function call) there. Put it in setup().
More code that should be inside a function, like setup() or loop().
