expected constructor, destructor, or type conversion before '(' token
int duration, distance; digitalWrite(trigPin,HIGH); delayMicroseconds(1000); digitalWrite(trigPin,LOW); duration = pulseIn(echoPin,HIGH); distance = (duration/2)/29.1;
what am I doing wrong?
You haven't posted complete code and you aren't using code tags. That's what you've done wrong. As for the cause of the error it is impossible to say from only that snippet.
You have to put code INSIDE a function. Outside of functions the only thing you can do is declare global variables. "digitalWrite" is not a variable declaration.
sketch_apr29b:2: error: expected constructor, destructor, or type conversion before '(' token
 digitalWrite(trigPin, HIGH);
sketch_apr29b:3: error: expected constructor, destructor, or type conversion before '(' token
sketch_apr29b:4: error: expected constructor, destructor, or type conversion before '(' token
 digitalWrite(trigPin, LOW);
sketch_apr29b:5: error: 'duration' does not name a type
 duration = pulseIn(echoPin, HIGH);
sketch_apr29b:6: error: 'distance' does not name a type
 distance = (duration / 2) / 29.1;
exit status 1
Once you put your code inside a function you will find that you forgot to define 'trigPin' and 'echoPin'.
void loop() {}
/Users/john/Documents/Arduino/sketch_apr29b/sketch_apr29b.ino: In function 'void setup()':
sketch_apr29b:3: error: 'trigPin' was not declared in this scope
sketch_apr29b:6: error: 'echoPin' was not declared in this scope
exit status 1
Thank you
