expected constructor, destructor, or type conversion before '(' token
My code is:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
int pirPin = 6;
int pirValue;
delay(61000)
pinMode(pirPin, INPUT);
lcd.begin(16, 2);
lcd.print(“Skye is awesome!”);
lcd.setCursor(4, 1);
if (pirValue = digitalRead(pirPin))
lcd.print(“WELCOME”);}
delay(6000);
else lcd.print(millis() / 1000);
Plz tell me what I have done wrong im new to this :confused:
Get rid of the delay before setup
Then you’ll have to fix the “else without previous else” error and/or mismatched brace
  lcd.print("WELCOME");}
That } ends the whole of loop() leaving a bunch of orphan code outside of any function. I don't think you meant to do that.
AutoFormat (Ctrl-T) in the IDE helps you spot things like that.
Steve
int pirPin = 6;
int pirValue;
lcd.begin(16, 2);
lcd.print(“JJ2020 is awesome!”);
delay(61000);
void loop() { //THIS IS WHERE THE IF/ELSE PROBLEM IS
delay(6000);
If you spot any errors please say so in the comments :slight_smile:
Thankyou,
Jack
Hello JJ2020,
if (pirValue = digitalRead(pirPin)) lcd.print("WELCOME");
The if ends after the semicolon. So the else has no if.
Regards, bidouilleelec
Here is your loop() function Auto Formatted in the IDE
void loop()                                         //THIS IS WHERE THE IF/ELSE PROBLEM IS
  delay(6000);
The only code dependent on the if is the lcd.print(), then there is an unconditional delay() before the else, hence the error message. If you want the delay() to be dependent on the test then put the dependent code in curly brackets like this
    delay(6000);
Note that I also chose to put the dependent code for the else in curly brackets as I feel it makes the code to be executed as a result of the if/else more obvious
(deleted)
Topics merged to avoid confusion and multiple answers in different topics
