expected constructor, destructor, or type conversion before ';' token
I am getting this error please help me
byte ipA = 192;
byte ipB = 168;
byte ipC = 1;
byte ipD = 140;
byte ip1 = EEPROM.read(0);
byte ip2 = EEPROM.read(1);
byte ip3 = EEPROM.read(2);
byte ip4 = EEPROM.read(3);
void ipd () {
if ( ip1 > 0) {
ipA = ip1;
ipB = ip2;
ipC = ip3;
ipD = ip4;
ipd (); //expected constructor, destructor, or type conversion before ';' token
That can’t be all your code
Please remember to use code tags when posting code.
Also, this is not an installation issue.
[color=#202124]code is as follows[/color]
this error message received
web-page-2:35:7: error: expected constructor, destructor, or type conversion before ‘;’ token
web-page-2:36:6: error: expected constructor, destructor, or type conversion before ‘(’ token
exit status 1
#include <Wire.h>
#include <EEPROM.h>
#include <EtherCard.h>
#define TCP_FLAGS_FIN_V 1
#define TCP_FLAGS_ACK_V 0x10
#define ETHERCARD_TCPCLIENT 4
byte ipA = 192;
byte ipB = 168;
byte ipC = 1;
byte ipD = 140;
void ipd () {
if ( ip1 > 0) {
ipA = ip1;
ipB = ip2;
ipC = ip3;
ipD = ip4;
ipd ();
delay(250);
static byte myip = { ipA, ipB, ipC, ipD };
static byte gwip = { 192, 168, 1, 1 };
static byte mymac = { 0x74, 0x69, 0x69, 0x2D, 0x30, 0x39 };
byte Ethernet::buffer[400];
char ipadresTextbox[15];
String a = “”;
String b = “”;
String x = “”;
String y = “”;
String z = “”;
String o = “”;
String son = “”;
String ip = “”;
String output_1 = “”;
String output_2 = “”;
String output_3 = “”;
String output_4 = “”;
String all_outputs = “”;
int byteSayisi = 0;
char dizi[16];
int byteSayisi0 = 0;
char dizi0[16];
int byteSayisi1 = 0;
char dizi1[16];
int byteSayisi2 = 0;
char dizi2[16];
String vgd = “”;
String vgd0 = “”;
char cikis[64];
int wrb;
bool ext = false;
BufferFiller bfill;
void eepromreset () {
int eeprombellek = 10 ;
for (int i = 0 ; i < eeprombellek ; i++) {
EEPROM.write(i, 0);
delay (100);
ss(0x00);
Again, the code is incomplete.
ipd ();
delay(250);
This code is not in a function.
thanks
