Hello everyone. Here is my code:
#include <AFMotor.h>
//----------------------Initialization & Setup---------------------------------------------------------------------------------------------------------------------------\\
//***********Motor Variables & Setup*************//
//Looking from the top view, where the front of the robot is the side where the ultrasonic sensor is facing, motor arrangement is:
//motor1: bottom left, motor2: bottom right, motor3: top right, motor4: top left
AF_DCMotor motor1(1, MOTOR12_64KHZ); // create motor #1, 64KHz pwm
AF_DCMotor motor2(2, MOTOR12_64KHZ); // create motor #2, 64KHz pwm
AF_DCMotor motor3(3, MOTOR12_64KHZ); // create motor #3, 64KHz pwm
AF_DCMotor motor4(4, MOTOR12_64KHZ); // create motor #4, 64KHz pwm
int mtr_Speed = 200; //Create variable for speed of the motors, out of 255
Serial.begin(9600); // set up Serial library at 9600 bps
Serial.println("Motor test!");
// sets the speed of each motor to the mtr_Speed variable
motor1.setSpeed(mtr_Speed);
motor2.setSpeed(mtr_Speed);
motor3.setSpeed(mtr_Speed);
motor4.setSpeed(mtr_Speed);
//----------------------Main Loop Function-------------------------------------------------------------------------------------------------------------------------------\\
void loop(){
goForward();
goBackward();
delay(4000);
//----------------------Functions to Drive the Robot---------------------------------------------------------------------------------------------------------------------\\
void goForward(){
motor1.run(FORWARD); // turn on all the motors to go in the forward direction
motor2.run(FORWARD);
motor3.run(FORWARD);
motor4.run(FORWARD);
void goBackward(){
motor1.run(BACKWARD); // turn on all the motors to go in the backward direction
motor2.run(BACKWARD);
motor3.run(BACKWARD);
motor4.run(BACKWARD);
void turnLeft(){
motor1.run(BACKWARD); // turn on right motors and reverse the left motors in order to turn the robot to the left
void turnRight(){
motor1.run(FORWARD); // turn on right motors and reverse the left motors in order to turn the robot to the left
void stopCar(){
motor1.run(RELEASE); // stops all motors
motor2.run(RELEASE);
motor3.run(RELEASE);
motor4.run(RELEASE);
I get the error message:
Arduino: 1.8.13 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
AF_LIbrary_Motor_test_2:33:14: error: expected constructor, destructor, or type conversion before ';' token
goForward();
AF_LIbrary_Motor_test_2:34:15: error: expected constructor, destructor, or type conversion before ';' token
goBackward();
AF_LIbrary_Motor_test_2:35:8: error: expected constructor, destructor, or type conversion before '(' token
delay(4000);
AF_LIbrary_Motor_test_2:36:1: error: expected declaration before '}' token
exit status 1
option enabled in File -> Preferences.
How can this problem be solved? Thanks.
