expected constructor, destructor, or type conversion before....
Hi
This is my code:
#include <stdio.h>
#include <string.h>
#include <ESP8266WiFi.h>
char myTopicPrefix[20];
char clientID[20];
strcpy(myTopicPrefix,"CGTK");
strcat(myTopicPrefix, ((String)ESP.getChipId()).c_str());
strcpy(clientID, "CGUID");
strcat(clientID, ((String)ESP.getChipId()).c_str());
And this is the error message I get:
error: expected constructor, destructor, or type conversion before '(' token
The first lines are out of the setup() on purpose and need to be before it.
What am I doing wrong?
thanks…
Have you tried commenting out all but one line to see what the machine is upset about?
-jim lee
This:
it must be in function body.
Budvar10:
This:
strcpy(clientID, “CGUID”);
I tried to put it in function buddy:
#include <stdio.h>
#include <string.h>
char clientID[20];
char clientID[20];
void beforeSetup(){
beforeSetup();
but I keep getting this error:
error: expected constructor, destructor, or type conversion before ';' token
 beforeSetup();
The code that you posted has several errors, staring with multiple declarations of variables
char clientID[20];
char clientID[20];
and the fact that ESP is not declared at all
and the call to beforeSetup(); is still not in a function.
Have you posted the correct code ?
UKHeliBob:
char clientID[20];
char clientID[20];
Hi you right I posted by mistake I fixed the code:
#include <stdio.h>
#include <string.h>
char clientID[20];
void beforeSetup(){
beforeSetup();
And I think that
UKHeliBob:
Is the reason that the code fail to compile. Why do I need to call beforeSetup() inside a function.what if I need to do this before setup()?
If you want to call the function in C, it must be from another function body. It is C syntax. On the top level is the function main(). C program must contain it, but Arduino is also for noobs and the main() is hidden. There are setup() and loop() instead. Everything you must write into their body. Setup() is executed once after resetting the Arduino and loop() is executed after setup again and again, till the Arduino will be powered.
Call it as the first thing in setup()
