"Expected" error
Hi, could anyone help solving problem in code from Arduinoos page? Thanks
I’m gettin’ this error:
ACO.cpp: In function 'void loop()':
ACO:73: error: expected `<' before '(' token
ACO:73: error: expected type-specifier before '(' token
ACO:73: error: expected `>' before '(' token
inside this PDE:
	MicroTLS: tiny light show
	Copyright (C) 2012 Didier Longueville
	This program is free software: you can redistribute it and/or modify
	it under the terms of the GNU General Public License as published by
	the Free Software Foundation, either version 3 of the License, or
	(at your option) any later version.
	This program is distributed in the hope that it will be useful,
	but WITHOUT ANY WARRANTY; without even the implied warranty of
	MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
	GNU General Public License for more details.
	You should have received a copy of the GNU General Public License
	along with this program.  If not, see <http://www.gnu.org/licenses/>.
#include <PlainADC.h>
#include <PlainFFT.h>
PlainADC PADC; /* Create ADC object */
PlainFFT FFT; /* Create FFT object */
/* Constants */
#define SCL_INDEX 0x00
#define SCL_TIME 0x01
#define SCL_FREQUENCY 0x02
/* Data acquisition parameters */
const uint16_t samples = 64;
const double samplingFrequency = 16.0E+3;
const uint16_t adcChannel = 0; /* From 0 to 5 on ATmega328 powered Arduinos */
const uint16_t refVoltage = ADC_REF_VOL_DEFAULT; /* VCC: 5V */
/* Data acquisition vector */
uint8_t *vBuffer;
const uint16_t leds = 3;
const double triggerLevel = 10.0;
/* FFT vectors */
double *vReal;
double *vImag;
	/* Set data acquisition parameters */
	vBuffer = PADC.SetAcquisitionEngine(adcChannel, refVoltage,  samplingFrequency, samples, ADC_DAT_FMT_DBL);
	/* Size data vectors */
	vReal = (double*)malloc(samples * sizeof(double));
	vImag = (double*)malloc(samples * sizeof(double));
	/* Set output ports */
	DDRD |= (1 << PIND7);
	DDRB |= ((1 << PINB0) | (1 << PINB1) | (1 << PINB2) | (1 << PINB3) | (1 << PINB4) | (1 << PINB5));
	for (uint8_t i = 0; i < leds; i++) {
		PORTB |= (1 << i);
		PORTB &= ~(1 << i);
	for (uint8_t i = 0; i < 6; i++) {
		PORTB ^= ((1 << PINB0) | (1 << PINB1) | (1 << PINB2) | (1 << PINB3) | (1 << PINB4) | (1 << PINB5));
	// blinkLed(3, 400);
	/* Mark event: flicker led */
	PORTD ^= (1 << PIND7);
	/* Acquire data */
	PADC.GetScanData();
	/* Cast data in a doubles vector */
	vReal = reinterpret_cast(vBuffer);
	/* Suppress data offset */
	FFT.SuppressOffset(vReal, samples);
	/* Clear imaginary vector */
	FFT.ClearVector(vImag, samples);
	/* Optional */
	// PrintVector(vReal, samples, SCL_TIME);
	/* Window data: optional */
	FFT.Windowing(vReal, samples, FFT_WIN_TYP_HAMMING, FFT_FORWARD);
	/* Compute FFT */
	FFT.Compute(vReal, vImag, samples, FFT_FORWARD);
	/* Compute magnitudes */
	FFT.ComplexToReal(vReal, vImag, samples, FFT_SCL_TYP_AMPLITUDE);
	/* Normalize data */
	FFT.Normalize(vReal, (samples >> 1), 100.0);
	/* Optional */
	// PrintVector(vReal, (samples >> 1), SCL_FREQUENCY);
	// PlotVector(vReal, (samples >> 1), SCL_FREQUENCY);
	/* And now the show must start ! */
	uint16_t samplesPerLed = uint16_t((samples >> 1) / leds);
	for (uint16_t i = 0; i < leds; i++) {
		double sum = 0.0;
		for (uint16_t j = 0; j < samplesPerLed; j++) {
			sum += vReal[(i * samplesPerLed) + j];
		double average = (sum / samplesPerLed);
		if (average > triggerLevel) {
			PORTB |= (1 << i);
		else {
			PORTB &= ~(1 << i);
void PrintVector(double *vData, uint8_t bufferSize, uint8_t scaleType)
	for (uint16_t i = 0; i < bufferSize; i++) {
		double abscissa;
		/* Print abscissa value */
		switch (scaleType) {
		case SCL_INDEX:
			abscissa = double(i);
		case SCL_TIME:
			abscissa = (i / samplingFrequency);
		case SCL_FREQUENCY:
			abscissa = ((i * samplingFrequency) / samples);
		Serial.print(abscissa, 6);
		Serial.print("t");
		Serial.print(vData[i], 4);
void PlotVector(double *vData, uint8_t bufferSize, uint8_t scaleType)
		double abscissa;
		case SCL_INDEX:
		case SCL_TIME:
		case SCL_FREQUENCY:
		Serial.print(abscissa, 1);
		Serial.print("t");
		uint8_t ordinate = vData[i];
		ordinate >>= 2;
		for (uint8_t j = 0; j < ordinate; j++) {
			Serial.print('X');
void blinkLed(uint16_t cycles, uint16_t duration)
/* Blink control led */
	/* Reset pin state */
	PORTD &= ~(1 << PIND7); /* Turn control led off */
	for (uint8_t i = 0; i < (cycles << 1); i++)	{
		delay(duration >> 1);
I'm guessing your reinterpret cast is the problem.
You have used reinterpret_cast wrong. You have to tell it what to reinterpret the cast as:
	 vReal = reinterpret_cast<double*>(vBuffer);
Oh :fearful: ...Thanks a lot :slight_smile:
in the loop() function, go to the line that says:
And change it to:
The proper syntax for reinterpret_cast is reinterpret_cast < type-id > ( expression ) so it’s expecting the type to cast to
