expected initializer before "buttonstate" token error message
Very first sketch! Having issues implementing variable.
Error code reads “expected initializer before “buttonstate” token”
This is my sketch;
Thank you!
#include <Servo.h>
long randomNumber;
Servo myservo;
int pos = 0;
int buttonPin = 7;
int ledPin = 8;
boolean on = false;
int buttonstate = 0;
myservo.attach(9);
randomSeed(analogRead(0));
pinMode(ledPin, OUTPUT);
pinMode(buttonPin, INPUT);
buttonstate = digitalRead(buttonPin);
if (buttonstate == HIGH) {
if (on == true) {
on = false;
on = true;
if (on == true) {
digitalWrite(ledPin, HIGH);
else {
digitalWrite(ledPin, LOW);
randomNumber = random(10000);
Serial.print(“random:”);
Serial.println(randomNumber);
randomNumber = map(randomNumber, 0, 10000, 0, 180);
Serial.print(“servo:”);
myservo.write(randomNumber);
for (pos = 0; pos <= 180; pos += 1)
myservo.write(pos);
delay(100);
for (pos = 180; pos >= 0; pos -= 1)
myservo.write(pos);
delay(10000);
Missing { brace.
Missing code tags
TolpuddleSartre:
Missing { brace.
Missing code tags
I just placed a { brace before it and now it says; a function-definition is not allowed here before '{' token
Any idea how i can fix this?
You placed before which "it"?
loop () is a function, just like setup().
Take a look and see if you can see how setup() begins.
I mean i put a {brace after void loop()
Like this:
void loop(){
if (on == true) {
on = false;
on = true;
I now gives me the message: a function-definition is not allowed here before '{' token
:frowning:
And it gives you a line where that happens.
If you change something, post the whole correction.
In code tags.
I think you need to put a space between void loop() and {
Also try this:
if (digitalRead(buttonPin) = HIGH) {
Usually that never works for me somehow.
#include <Servo.h>
long randomNumber;
Servo myservo;
int pos = 0;
int buttonPin = 7;
int ledPin = 8;
boolean on = false;
  myservo.attach(9);
      if (on == true) {
        on = false;
      }  else {
        on = true;
  if (on == true) {
  else {
  Serial.print("random:");
  Serial.print("servo:");
    myservo.write(pos);
    delay(100);
    myservo.write(pos);
  delay(10000);
I hope this is what you mean
Use this code:
#include <Servo.h>
long randomNumber;
Servo myservo;
int pos = 0;
int buttonPin = 7;
int ledPin = 8;
boolean on = false;
  myservo.attach(9);
      if (on == true) {
        on = false;
      }  else {
        on = true;
  if (on == true) {
  else {
    myservo.write(pos);
    delay(100);
    myservo.write(pos);
  delay(10000);
You placed too many braces.
Hope this helps.
Hint: Use the IDE's auto format.
Your code looks like it has been typed by a barrelful of drunk monkeys.
Yes the code has no more error massages.
The onlly thing now is, that the cercuit i build (it haves a servo and a led + pushbutton, that i want to put on and off) does’t work for the led and button, onlly the servo does his work. any idea how to make it that i both works? or do i go to another forum to ask about this specific problem?
#include <Servo.h>
long randomNumber;
Servo myservo;
int pos = 0;
int buttonPin = 7;
int ledPin = 8;
boolean on = false;
  myservo.attach(9);
      if (on == true) {
        on = false;
      }  else {
        on = true;
  if (on == true) {
  else {
    myservo.write(pos);
    delay(100);
    myservo.write(pos);
  delay(10000);
Unsigned_Arduino:
No, C++ doesn't care about a space there.
Also try this:
That's because you can't assign HIGH to digitalRead(buttonPin). Try using the comparison operator == instead of the assignment operator =.
If tried it, but it does't seem to work. If i put onlly one = it turns on and off with the servo when it turns. I just want to make the survo move randomly and the LED put on and off when i push the button.
Whoops.
  if (digitalRead(buttonPin) == HIGH) {
:o
