expected initializer before 'char'
I have just tried to recompile my 3 year old arduino code by using the latest arduino IDE.
Following error comes up and I have not found a solution by searching the forum.
Error:
Code:
// Define namespace
namespace FreqPeriod {
extern volatile unsigned char f_capt;
extern volatile unsigned int capta;
extern volatile unsigned long captd;
extern volatile int ocnt;
  void begin();
  unsigned long int getPeriod();
// Define global variables for IRQ functions
volatile unsigned char FreqPeriod::f_capt;              // THIS LINE CAUSES THE ERROR
volatile unsigned int FreqPeriod::capta;
volatile unsigned long int FreqPeriod::captd;
volatile int FreqPeriod::ocnt;
I have realized, that there are generally syntax changes with the new IDE but would be have to have an explanation/solution for the above problem.
The error message is missing.
Where did you read that ?
Added to a bare minimum sketch your code snippet compiles for me
IDE 1.8.10
Nano board
Windows 10
Which version of the IDE, board and OS are you using ?
Post the whole code. When posting snippets, the problem is often in the part not posted.
Post the entire error message. It is easy to do. There is a copy error message button in the IDE. Copy the error and paste in a post in code tags. Paraphrasing the error message leaves out important information.
Thanks for your replies !
I found the problem, there was
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
further below in my code.
As my code is now some years old I can't remember the reason for that fragment, but by removing it my old program compiles.
Problem solved !
Thanks again !
BTW: The Error message was: expected initializer before 'char' given in my first post...
The complete error message would include the line number, character position and file as well.
lichti:
BTW: The Error message was: expected initializer before ‘char’ given in my first post…
BTW there was more of it than that.
You could have posted the actual error message.
lichti:
What you discovered was not a "syntax" change. The language is C/C++ so unless the standard changes the syntax will not change.
