expected initializer before 'if'
Hello I had some trouble with my code here is the full error message:
Arduino: 1.8.5 (Windows 7), Board: "Arduino/Genuino Uno"
sketch_feb08b_v.2:28: error: expected initializer before 'if'
    if (DEBUG) { {
exit status 1
option enabled in File -> Preferences.
And here is my full code:
  /* Copyright (c) 2015 by http://www.electrominds.com
  * Simple Arduio Theremin "Theremino" Project
  * Project URL: http://www.electrominds.com/projects/simple-arduino-theremin-theremino
  * This file is free software; you can redistribute it and/or modify
  * it under the terms of either the GNU General Public License version 2
  * or the GNU Lesser General Public License version 2.1, both as
  * published by the Free Software Foundation.
  * Required libraries:
  * NewPing: https://code.google.com/p/arduino-new-ping/downloads/detail?name=NewPing_v1.5.zip
  * toneAC: https://code.google.com/p/arduino-tone-ac/downloads/detail?name=toneAC_v1.2.zip
  #include <NewPing.h>
  #include <toneAC.h>
 #define DEBUG         false // Set to true to enable Serial debug
 #define TONE_PIN      8
 #define TONE_VOLUME   10   // 1-20
 #define TRIGGER_PIN   12   // Board pin tied to trigger pin on the ultrasonic sensor.
 #define ECHO_PIN      11   // Board pin tied to echo pin on the ultrasonic sensor.
 #define MAX_DISTANCE  200  // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
 NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
   if (DEBUG) { {
     Serial.println("Theremino starting");
   delay(30); // Wait 30ms between pings (about 33 pings/sec). 29ms should be the shortest delay between pings.
   unsigned long uS = sonar.ping(); // Send ping, get ping time in microseconds (uS).
   if (DEBUG) Serial.println(uS);
   if (uS > 2000) { // Range is about 0-30 cm from sensor
     toneAC(0); // Turn sound off when not in range
     if (DEBUG) Serial.println("No tone");
     int freq = 2000 - uS / 1.5; // Get sound frequency
     toneAC(freq, TONE_VOLUME); // Play it!
     if (DEBUG) Serial.println(freq);
(deleted)
