ругается на команду int что мне делать? программа из справочника по сборке авто keystudio
#include <Wire.h>
#define SensorLeft 6 //input pin of left sensor
#define SensorMiddle 9 //input pin of middle sensor
#define SensorRight 11 //input pin of right sensor
unsigned char SL; //state of left sensor
unsigned char SM; //state of middle sensor
unsigned char SR //state of right sensor
#define Lpwm_pin 5 //pin of controlling speed----ENA of motor driver board
#define Rpwm_pin 10 //pin of controlling speed----ENA of motor driver board
int pinLB=2; //pin of controlling diversion----IN1 of motor driver board
int pinLF=4; //pin of controlling diversion----IN2 of motor driver board
int pinRB=7; //pin of controlling diversion----IN3 of motor driver board
int pinRF=8; //pin of controlling diversion----IN4 of motor driver board
unsigned char Lpwm_val=180;//the speed of left wheel at 180 in initialization
unsigned char Rpwm_val=180;//the speed of right wheel at 180 in initialization
int Car_state=0; //state of car moving
LiquidCristal_I2C lcd(0x27,16,2) //set the LCD adress to 0x27 for a 16 chars and 2
void LCD1602_init(void)
icd.init();
icd.backlight();
icd.clear();
void Sensor_IO_Config()
pinMode(SensorLeft,INPUT);
pinMode(SensorMiddie,INPUT);
pinMode(SensorRight,INPUT);
void Sensor_Scan(void)
SL=digitalRead(SensorLeft);
SM=digitalRead(SensorMiddle);
SR=digitalRead(SensorRight);
void M_Control_IO_config(void)//initialized function of IO of motor driver
pinMode(pinLB,OUTPUT);//pin 2--IN1 of motor driver board
pinMode(pinLF,OUTPUT);//pin 4--IN2 of motor driver board
pinMode(pinRB,OUTPUT);//pin 7--IN3 of motor driver board
pinMode(pinRF,OUTPUT);//pin 8--In4 of motor driver board
pinMode(Lpwm_pin,OUTPUT);//pin 5 (PWM)--ENA of motor driver board
pinMode(Rpwm_pin,OUTPUT);//pin 10 (PWM)--ENB of motor driver board
void Set_Speed(unsigned char Left,unsigned char Right)/./setting function of speed
analogWrite(Lpwm_pin,Left);
analogWrite(Rpwm_pin,Right);
void advance() //going forwards
digitalWrite(pinRB,LOW); //making motor move towards right rear
digitalWrite(pinRF,HIGH);
digitalWrite(pinLB,LOW); //making motor move towards left rear
digitalWrite(pinLF,HIGH);
Car_state=1;
show_state();
void turnR() //turning on the right(dual wheels)
digitalWrite(pinLB,HIGH);
digitalWrite(pinLF,LOW); //making motor move towards left front
Car_state=4;
show_state();
void turnL() //turning on the left(dual wheels)
digitalWrite(pinRB,HIGH);
digitalWrite(pinRF,LOW); //making motor move towards right front
Car_state=3;
show_state();
void stopp() //stop
Car_state=5;
show_state();
void back() //back
digitalWrite(pinRB,HIGH); //making motor move towards right rear
digitalWrite(pinLB,HIGH); //making motor move towards left rear
Car_state=2;
show_state();
void show_state(void) //showing current state of the car
lcd.setCursor(0,1); //showing from second row
switch(Car_state )
case 1:lcd.print("GO ");Serial.print("\n GO");
case 2:lcd.print("Back");Serial.print("\n Back");
case 3:lsd.print("Left");Serial.print("\n Left");
case 4:lcd.print("Right");Serial.print("\n Right");
case 5:lcd.print("Stop");Serial.print("\n Stop");
default:
LCD1602_init();
Sensor_IO_Config();
M_Control_IO_config();//motor controlling the initialization of IO
Set-Speed(Lpwm_val);//setting initialization of speed
lcd.clear();
lcd.setCursor(0,0); //cursor set in first row and first column,
lcd.print(" Wait Signal ");
stopp();
unsigned char old_SL,old_SR;
Sensor_Scan();
if(SM=HIGH)//middle sensor in black area
if(SL=LOW & SR=HIGH) //black on left, white on right, turn left
turnR();
else if (SR=LOW & SL=HIGH)//white on left, black on right, turn right
turnL();
else //white on both sides, going forward
advance();
else//middle sensor on white area
if(SL==LOW&SR--HIGH)//black on left, white on right, turn left
turnR();
else if(SR==LOW&SL==HIGH)//white on left, black on right, turn left
turnL()
else //all white, stop
back();
delay(100);
stopp();
