expected initializer
Arduino: 1.6.12 (Mac OS X), Board: "Arduino/Genuino Uno"
sketch_nov13a:15: error: expected initializer before 'if'
if (buttonState == HIGH) {
exit status 1
option enabled in File -> Preferences.
Clearly, the error is in the code that you didn't post. Please post it, (between [code]code tags[/code]).
Incidentally, all error messages should also be placed between code tags, not posted inline.
Actual_Dragon:
exit status 1
Well, we need to see what you have before your "if".
Please use code tags.
Read this before posting a programming question
How to use this forum
I guess a missing semi-colon :wink:
#include <Servo.h>
Servo servoLeft; // Define left servo
Servo servoRight; // Define right servo
const int buttonPin = 2; // the number of the pushbutton pin
servoLeft.attach(A5); // Set left servo to analog pin 5
servoRight.attach(A4);// Set right servo to analog pin 4
pinMode(buttonPin, INPUT);
void forward() {
servoLeft.write(0);
servoRight.write(180);
else(
Missing {
Missing code tags
  void forward() {
What's that "void" doing there?
void loop(){
forward() {
servoLeft.write(0);
where do i put it?
C/C++ (or at least the Arduino dialect) doesn't allow nested function definitions, so I'd say "outside of your current function".
Actual_Dragon:
void loop(){
forward() {
servoLeft.write(0);
where do i put it?
@Actual_Dragon - start using code tags before I start locking your thread.
AWOL:
Actually GCC does support nested functions, but only in C, not C++.
oqibidipo:
Actually, I wrote "C/C++ (or at least the Arduino dialect) doesn't allow nested function definitions".
I know very well that nested functions can be allowed.
/Users/svteacher/Documents/Arduino/sketch_nov13a/sketch_nov13a.ino: In function 'void loop()':
sketch_nov13a:22: error: no match for call to '(Servo) (int)'
servoLeft(180);
sketch_nov13a:23: error: no match for call to '(Servo) (int)'
servoRight(0);
sketch_nov13a:25: error: no match for call to '(Servo) (int)'
servoLeft(90);
sketch_nov13a:26: error: no match for call to '(Servo) (int)'
servoRight(90);
exit status 1
im getting this after i type this
[void loop(){
val==digitalRead(buttonPin); //read input value
if (val=HIGH) { //check if input is high
servoLeft(180);
servoRight(0);
delay(6000);
servoLeft(90);
servoRight(90);
Are you missing some ".write"s?
You're certainly missing code tags.
Still.
Edit: ironically, it seems you're also missing the code that caused the error.
Actual_Dragon:
void loop(){
forward() {
servoLeft.write(0);
where do i put it?
You put it before and after everything that's code. Put
** **[code]** **
before void loop(){ and put
** **[/code]** **
after servoRight.write(180).
