Expected numeric before constant error
hi im trying to code my stepper motors with servo and i get the error expected numeric before constant heres my code
#include<Servo.h>
Servo myservo;
#define stepper1_pin 4
#define stepper2_pin 5
#define stepper3_pin 6
#define stepper4_pin 7
#define stepper5_pin 8
#define stepper6_pin 9
#define stepper7_pin 10
#define stepper8_pin 11
pinMode(stepper1_pin 4,OUTPUT);
pinMode(stepper2_pin 5,OUTPUT);
pinMode(stepper3_pin 6,OUTPUT);
pinMode(stepper4_pin 7,OUTPUT);
pinMode(stepper5_pin 8,OUTPUT);
pinMode(stepper6_pin 9,OUTPUT);
pinMode(stepper7_pin 10,OUTPUT);
pinMode(stepper8_pin 11,OUTPUT);
myservo.attach(2);
digitalWrite(stepper1_pin 4, HIGH);
digitalWrite(stepper2_pin 5, LOW);
digitalWrite(stepper3_pin 6, HIGH);
digitalWrite(stepper4_pin 7, LOW);
myservo.write(90);
delay(2000);
digitalWrite(stepper5_pin 8, LOW);
digitalWrite(stepper6_pin 9, HIGH);
digitalWrite(stepper7_pin 10, LOW);
digitalWrite(stepper8_pin 11, HIGH);
myservo.write(90);
delay(2000);
digitalWrite(stepper3_pin 6, LOW);
digitalWrite(stepper4_pin 7, HIGH);
myservo.write(90);
delay(2000);
digitalWrite(stepper7_pin 10, HIGH);
digitalWrite(stepper8_pin 11, LOW);
myservo.write(90);
delay(3000);
can some help me
Welcome to the forum
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Check the syntax of the digitalWrite() function
What values are you trying to call it with ?
You probably mean
  pinMode(stepper8_pin, OUTPUT);
The pre-processor will replace stepper8_pin with 11 when the code is compiled because of your #define
yes thank you your right it worked now thanks
Do you understand what was wrong ?
