expected ',' or ';' before void error
Hello. Complete newbie here. Trying to test a photocell input. I used the built in digital read serial sketch and get this error when I try to upload. Is this an easy fix? Here is my sketch and thanks in advance.
  DigitalReadSerial
  Reads a digital input on pin 2, prints the result to the Serial Monitor
  This example code is in the public domain.
  http://www.arduino.cc/en/Tutorial/DigitalReadSerial
// digital pin 2 has a pushbutton attached to it. Give it a name:
int pushButton = 2;
int PNP = 10
// the setup routine runs once when you press reset:
  // initialize serial communication at 9600 bits per second:
  // make the pushbutton's pin an input:
  pinMode(PNP, INPUT);
// the loop routine runs over and over again forever:
  // read the input pin:
  int PNPState = digitalRead(PNP);
  // print out the state of the button:
  Serial.println("PNP State = " + (String) PNPState);
  Serial.println( " " ) ;
  delay(1);        // delay in between reads for stability
int PNP = 10
Missing a semicolon
