expected primary-expression before '>' token AND ALSO error: 'left' was not de..
SOLVED.
that is my code:
#include <Wire.h>
#include <HMC5883L.h>
HMC5883L compass;
char blueToothVal;
  pinMode (13, OUTPUT);
  pinMode (10, OUTPUT);
  pinMode (9, OUTPUT);
  pinMode (7, OUTPUT);
  pinMode (6, OUTPUT);
  compass = HMC5883L();
  if (Serial.available())
    blueToothVal = Serial.read();
  MagnetometerRaw raw = compass.ReadRawAxis();
  float heading = atan2(raw.YAxis, raw.XAxis);
  if (heading < 0)
    heading += 2 * PI;
  float headingDegrees = heading * 180 / M_PI;
  if (blueToothVal == 2)
    //North 360
    if (headingDegrees < 350)
      if (headingDegrees < 250)
        Left(1);
        left(0);
    if (headingDegrees > 10)
      if (headingDegrees < 110)
        Right(1);
        Right(0);
  if (blueToothVal == 4)
    //west 90
    if (headingDegrees < 80)
      if (headingDegrees < 360 && headingDegrees > 230)
        Left (1);
        Left (0);
    if (headingDegrees > 100 && headingDegrees < 230)
      if (headingDegrees > 200)
        Right (1);
        Right (0);
  if (blueToothVal == 6)
    if (headingDegrees < 260)
      if (headingDegrees < 160 && headingDegrees => 60)
        Left (1);
        Left (0);
    if (headingDegrees > 280)
      if (headingDegrees > 0 && < 60)
        Right (1);
        Right (0);
  if (blueToothVal == 8)
    // south 180
    if (headingDegrees < 170)
      if (headingDegrees < 100)
        Left (1);
        Left (0);
    if (headingDegrees > 190)
      if (headingDegrees > 290)
        Right (1);
        Right (0);
  delay(300);
void Right(int a)
  if (a == 0)
    analogWrite (11, 180);
    analogWrite (5, 180);
    analogWrite (11, 255);
    analogWrite (5, 255);
  digitalWrite(6, 0);
  digitalWrite(7, 1);
  digitalWrite(9, 0);
  digitalWrite(10, 1);
void Left(int a)
  if (a == 0)
  digitalWrite(6, 1);
  digitalWrite(7, 0);
  digitalWrite(9, 1);
  digitalWrite(10, 0);
now there are 2 errors:
back_to_the_direction.ino: In function ‘void loop()’:
back_to_the_direction:37: error: ‘left’ was not declared in this scope
back_to_the_direction:64: error: expected primary-expression before ‘>’ token
back_to_the_direction:69: error: expected primary-expression before ‘<’ token
May someone please explame me what I did wrong?
SFBE,
tnks.
Need to put prototypes in, as you call the functions before declaring them. Put these lines above your loop():
void Right(int a);
void Left(int a);
tammytam:
void Right(int a);
void Left(int a);
found the problem, left, !Left, but what with the second problem?
solved! sorry for To bother you :slight_smile:
The IDE adds function prototypes, and even does it correctly most of the time.
in C==, the operator is >=.
left() is different from Left()
Also:
Second part of that statement is checking nothing is less than 60 :wink:
