"expected primary-expression before ')' token" error, but can't see a syntax err
I've been trying to resolve this issue for a month, and finally decided to seek help.
I have a nested "switch" statement in a function. Every time I try to compile, I get the error "expected primary-expression before ')' token". The error points to line 430, the inner switch statement itself, ["switch(Sub_Mode_Set_Timers){"]. For the life of me, I can't find any syntax problem on that line or in the code up to there from the beginning of the function. If I comment out that one line and its related "case" statements, the program compiles.
The program itself is a fan control system for a 3D printer that I am building for a friend.
To give you some idea of my (low level of) programming experience, I have done a little C++ and some other program languages over the years, but am little more than a novice with C++.
The error message and code are below. Please note that the code is nowhere near done. I am trying to establish the framework for how it will be structured first. I have not included the entire program, but the portions that I think may be relevant without posting hundreds of lines.
Any help would be greatly appreciated!
Thank you!
Charlie
Error Message
C:\Users\Owner\Documents\Arduino\Software\3D Printer Fan Control\Fan_Control_Software\John_Fan_Control_V1_00a_8_2_20\John_Fan_Control_V1_00a_8_2_20.ino: In function 'void MenuKeyRightPressed()':
John_Fan_Control_V1_00a_8_2_20:430:29: error: expected primary-expression before ')' token
Program Code
//-- Modes
enum Mode
	Mode_Start_Pause_Resume_Clock,
	Mode_Set_Timers,
	Mode_Edit_Timers
enum Sub_Mode_Set_Timers
	Sub_Mode_Set_Timers_Clear_Prev_Timers,
	Sub_Mode_Set_Timers_Enter_New_Timer,
	Sub_Mode_Set_Timers_Set_Power_Level,
	Sub_Mode_Set_Timers_Add_Timer
enum Sub_Mode_Edit_Timers
	Sub_Mode_Edit_Timers_Add_Timer,
	Sub_Mode_Edit_Timers_Delete_Timer,
	Sub_Mode_Edit_Timers_Edit_Timer,
	Sub_Mode_Edit_Timers_Edit_Power
// SNIP... code from enum to this function not shown
// BUTTON CLICK HANDLER - RIGHT
//	Some action
	bool Button_flag;
	Button_flag = true;
	snprintf(LCD_Row_1, 17, "Right Row 1     ");	//-- Store formatted version data for line 1
	snprintf(LCD_Row_2, 17, "Right Row 2     ");	//-- Store formatted version data for line 2
	PrintToLCD();
	switch(Mode)
		case Mode_Start_Pause_Resume_Clock:
		case Mode_Set_Timers:
			case Sub_Mode_Set_Timers_Clear_Prev_Timers:
			case Sub_Mode_Set_Timers_Enter_New_Timer:
			case Sub_Mode_Set_Timers_Set_Power_Level:
			case Sub_Mode_Set_Timers_Add_Timer:
		case Mode_Edit_Timers:
	Button_flag = true;
What is a "Sub_Mode_Set_Timers"?
"Sub_Mode_Set_Timers" is the integer variable in an enum type. It evaluates to a 0, 1, 2 or 3, depending upon the enum names in sequence assigned below.
No, "Sub_Mode_Set_Timers" is the name of an enum.
Sorry, you are right, it is the enum type-name.
But I just perceived that you may have meant "what is it FOR?" It is part of the menu system. If the user chooses "Set Timers", it goes into a subset of menus with further choices for setting the timers.
The point is that the enum is a type. You need a variable of that type in your switch statement. You apparently don't have one in the case the compiler is complaining about.
WildBill,
Ah, THAT'S what the issue is! I saw something similar done in a program that I had done some testing on, but in that case they must have declared a variable elsewhere in the program that I was unaware of. I thought that they were using the type name.
Many thanks to you and Formerly AWOL for setting me straight! I will implement it later tonight.
