expected primary-expression before '.' token error
I am trying to make a library but cant seem to solve this error? Can anyone see what I have done wrong?
Sketch
#include <CRC32.h>
Serial.begin(19200);
Serial.print("Begin");
Serial.println(Crc.version());
CRC32.H
#ifndef CRC32_h
#define CRC32_h
#include "Arduino.h"
class Crc{
  public:
	int version(void);
   	unsigned long calc(unsigned char message);
#endif
CRC32.cpp
#include "CRC32.h"
// ----------------------------- crc32b --------------------------------
/* This is the basic CRC-32 calculation with some optimization but no
table lookup. The the byte reversal is avoided by shifting the crc reg
right instead of left and by using a reversed 32-bit word to represent
the polynomial.
   When compiled to Cyclops with GCC, this function executes in 8 + 72n
instructions, where n is the number of bytes in the input message. It
should be doable in 4 + 61n instructions.
   If the inner loop is strung out (approx. 5*8 = 40 instructions),
it would take about 6 + 46n instructions. */
int Crc::version(void){
  return 1;
void Crc32::calc(unsigned char message) {
Serial.print(message);
   int i, j;
   unsigned long Byte, crc, mask;
   i = 0;
   crc = 0xFFFFFFFF;
   while (message[i] != 0) {
      Byte = message[i];            // Get next byte.
      Serial.println(message[i],HEX);
      crc = crc ^ Byte;
      for (j = 7; j >= 0; j--) {    // Do eight times.
         mask = -(crc & 1);
         crc = (crc >> 1) ^ (0xEDB88320 & mask);
      i = i + 1;
   return ~crc;
I think your .h should have "static int version(void);" and you should call the class-static method in the main program with "Crc::version()". The way it is written is using it as an instance method but you have not created an object instance yet.
In general, the name of the class is supposed to match the name of the file that it is defined in. Why doesn't your class name match your file name?
What is the purpose of having a class at all?
