Expected primary expression before '=' token, I fail to see the mistake
#include <DHTesp.h>
#include <GSM.h>
#include <GSM3CircularBuffer.h>
#include <GSM3IO.h>
#include <GSM3MobileAccessProvider.h>
#include <GSM3MobileCellManagement.h>
#include <GSM3MobileClientProvider.h>
#include <GSM3MobileClientService.h>
#include <GSM3MobileDataNetworkProvider.h>
#include <GSM3MobileMockupProvider.h>
#include <GSM3MobileNetworkProvider.h>
#include <GSM3MobileNetworkRegistry.h>
#include <GSM3MobileServerProvider.h>
#include <GSM3MobileServerService.h>
#include <GSM3MobileSMSProvider.h>
#include <GSM3MobileVoiceProvider.h>
#include <GSM3ShieldV1.h>
#include <GSM3ShieldV1AccessProvider.h>
#include <GSM3ShieldV1BandManagement.h>
#include <GSM3ShieldV1BaseProvider.h>
#include <GSM3ShieldV1CellManagement.h>
#include <GSM3ShieldV1ClientProvider.h>
#include <GSM3ShieldV1DataNetworkProvider.h>
#include <GSM3ShieldV1DirectModemProvider.h>
#include <GSM3ShieldV1ModemCore.h>
#include <GSM3ShieldV1ModemVerification.h>
#include <GSM3ShieldV1MultiClientProvider.h>
#include <GSM3ShieldV1MultiServerProvider.h>
#include <GSM3ShieldV1PinManagement.h>
#include <GSM3ShieldV1ScanNetworks.h>
#include <GSM3ShieldV1ServerProvider.h>
#include <GSM3ShieldV1SMSProvider.h>
#include <GSM3ShieldV1VoiceProvider.h>
#include <GSM3SMSService.h>
#include <GSM3SoftSerial.h>
#include <GSM3VoiceCallService.h>
#include<SoftwareSerial.h>
#include <DHT.h>
#define DHT11_PIN 7
SoftwareSerial mySerial(9,10);
int M_Sensor = A0;
int Motor1 = 13;
mySerial.begin(9600); // Setting the baud rate of GSM Module
pinMode(13,OUTPUT); // Setting the baud rate of Serial Monitor (Arduino)
int Moisture = analogRead(M_Sensor);
int chk = DHT.read11(DHT11_PIN);
if (Moisture> 700) // for dry soil
mySerial.println("MOTOR:ON మోటారు ఆన్లో ఉంది " );
digitalWrite(13, HIGH);
mySerial.println("AT+CMGF=1"); //Sets the GSM Module in Text Mode
delay(1000); // Delay of 1000 milli seconds or 1 second
mySerial.println("AT+CMGS="+919494112952"\r"); // Replace x with mobile number
mySerial.println("Temperature = ");// The SMS text you want to send
mySerial.println(DHT.temperature);
mySerial.print("Humidity = ");
mySerial.println(DHT.humidity);
delay(100);
mySerial.println((char)26);// ASCII code of CTRL+Z
digitalWrite(13, LOW);
mySerial.println("MOTOR:OFF మోటారు ఆగిపోయింది" );
if (Moisture>= 100 && Moisture<=700) //for Moist Soil
mySerial.println("SOIL IS IN MOIST CONDITION");
if (Serial.available()>0)
switch(Serial.read())
case 's':
SendMessage();
case 'r':
RecieveMessage();
if (mySerial.available()>0)
Serial.write(mySerial.read());
void SendMessage()
delay(100);
mySerial.println("Humidity = ");
delay(100);
void RecieveMessage()
mySerial.println("AT+CNMI=2,2,0,0,0"); // AT Command to receive a live SMS
@Sgowtham_vzg you forgot a couple of things:
  1. the error message
  2. code tags.
There are a lot of = in that code. I expect the real error message told you which one it was having trouble with.
Steve
slipstick:
Steve
"...the real error message ABSOLUTELY told you THE EXACT LINE AND CHARACTER POSITION which one it was having trouble with."
Well it didn't tell me that because I'm not the one with the dodgy code. But I know what you mean.
Steve
