Expected primary-expression before '.' token in code
While compilation erorr: expected primary-expression before '.' token
//=================Настройки=================//
const unsigned long timeClassic = 150000; //в миллисекундах
const unsigned long timeBlitz = 40000; //в миллисекундах
const unsigned long pik = 300; //в миллисекундах
//====================Код====================//
#include <Key.h> //библиотеки
#include <Keypad.h>
#include <LiquidCrystal.h>
//#include <GyverTimer.h>
#include <String.h>
const byte rs = A3, en = A5, d4 = 13, d5 = 12, d6 = 11, d7 = 10, button = 0, svet_red = A1, buzzer = A2, potenciometr = A0; //обозначаю все пины кроме кейпада
String code = "0";
int code1;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7); //пины экрана
const byte ROWS = 4; //кейпад начало
const byte COLS = 4;
char hexaKeys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte colPins[ROWS] = {5, 4, 3, 2};
byte rowPins[COLS] = {9, 8, 7, 6};
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS); //кейпад конец
unsigned long last_time;
byte valu = 0;
boolean gameOn, codeEnter, beepBeep;
boolean mode, flag_C;
char key;
byte coursorX, coursorY;
int simbolNo, pass, pass_int;
char s1, s2, s3, s4, s5, s6, s7, s8;
String pass_str;
  //GTimer myTimer(MS, period);
  pinMode(potenciometr, INPUT);
  pinMode(button, INPUT_PULLUP);
  //pik = 300;
  lcd.begin(16, 2);
  code1 = String.length(code);
  for(code <= 8){
    key = customKeypad.getKey();
    lcd.setCursor(0, 0);
    lcd.print(code);
    if(key){
      code = code + key;
  //menu();
void loop(){
  if(key){
    Serial.println(key);
    lcd.print(key);
void menu(){
  while(gameOn == 0){
    //char key = Keypad.waitForKey();
    if(key == '4'){
      mode = 0;
    if(key == '6'){
      mode = 1;
  lcd.print("      Menu");
  lcd.setCursor(0, 1);
  lcd.print("Mode:");
  //lcd.clear();
  if(mode == 0){
    lcd.setCursor(5, 1);
    lcd.print("  classic");
    //Serial.println("classic");
  if(mode == 1){
    lcd.print("  blitz");
    //Serial.println("blitz");
  if(key == '5'){
    if(mode == 0){
      gameOn = 1;
      lcd.clear();
      gameStartClassic();
    if(mode == 1){
      gameOn = 1;
      lcd.clear();
      //gameStartBlitz();
//Классический режим игры
void gameStartClassic(){
  codeEnter = 1;
  while(gameOn == 1){
    while(codeEnter == 1){
    lcd.print("   Time: ");
    lcd.print(timeClassic / 1000 / 60);
    lcd.print(":");
    lcd.print(timeClassic / 1000 % 60);
    lcd.print(" Code: ");
    while(beepBeep == 1){
//Блитз режим
void gameStartBlitz(){
  codeEnter = 1;
  while(gameOn == 1){
    lcd.print(timeBlitz / 1000 / 60);
    lcd.print(":");
    lcd.print(timeBlitz / 1000 % 60);
    lcd.print("   Time left: ");
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
Welcome to the forum
You have used the wrong syntax for the length() function
ie, if you wanted to print the length of a String named wibble you would write
  String wibble = "Hello";
  Serial.println(wibble.length());
thank you, i thought this forum is slowly)
Didn't the compiler barf on that?
