expected primary-expression before '=' token
I am working on a school project to get a path to write to a text file, and get this error when I verify the code. Here is the complete code
#include <SPI.h>
#include <SD.h>
File myFile;
int coord[2][300];
  // SD card check
  Serial.print("Initializing SD card...");
  if (!SD.begin(4))
    Serial.println("initialization failed!");
    while (1);
  Serial.println("initialization done.");
  //Declarations
  int n[300];
  // open the file for reading:
  myFile = SD.open("data.txt");
  if (myFile)
    Serial.println("data.txt:");
  // read from the file and output int values to n array
    while (myFile.available())
    arrayOfChars = myFile.read();
    myFile.close();
    for (int i=0; i<300; i++)
      n[i] = atoi(arrayOfChars);
  else{
    Serial.println("error opening test.txt");
 The coord array has 2 rows and 300 columns.
 [1][i] is the x axis
 [2][i] is the y axis
//Finds size of array and building output code to text file
//int size = sizeof(n) / sizeof(int);
myFile = SD.open("map.txt", FILE_WRITE);
  for (int i=300; i>0; i--)    //i equals whatever the length of the array is
   int x=1;
   while (x<i)
     myFile.print(" ");
     x++;
    if (round(coord[1][i]-coord[1][i-1]))= 0) //ERROR?
      if (round(coord[2][i]-coord[2][i-1]) > 0)
        up = round(coord[2][i]-coord[2][i-1]);
        while (up >= 1)
          myFile.println("|"); //not sure if this will be in the same line
          up--;
      elseif (round(coord[2][i]-coord[2][i-1]) < 0)
        down = round(coord[2][i]-coord[2][i-1]);
        while (down >= 1)
         myFile.println(" "); //prints on the next line down
         down--;
        //do nothing
     if (round(coord[2][i]-coord[2][i-1]))== 0)
      if (round(coord[1][i]-coord[1][i-1]) > 0)
        right = round(coord[2][i]-coord[2][i-1]);
        while (right >= 1)
          myFile.print("_");
          right--;
      elseif (round(coord[1][i]-coord[1][i-1]) < 0)
        left = round(coord[2][i]-coord[2][i-1]);
        while (left >= 1)
         myFile.print("_"); //not sure how to go back with the _ line
         down--;
        //do nothing
Where is arrayOfChars declared?
Further myFile.read() reads a single character, not an array.
I commented that part out since I am still working on it. I am having trouble after this line of code:
Yes. Count the number of begin parentheses and the number of end parentheses. They should be equal.
You will also have trouble with "=". One "=" is an assignment statement which is why you get the error message because the left of an assignment must be a variable, not an expression. Two "==" is the comparison operator which would make more sense there.
Pete
Thanks. You helped me solve my problem.
jtsao3:
Hopefully, the solution you found also included correcting the out-of-bounds array accesses.
