expected primary-expression before '[' token
Hallo,
Ich baue mir grade eine Library für Ein touchdisplay zusammen, womit ich auf dem display abfragen kann, ob der gedrückte Punkt in einem zuvor definierten bereich liegt.
Leider kommt es dabei zu nür mich unerklährlichen Fehlern:
C:\Users\Flo\AppData\Local\Temp\arduino_build_130905\sketch\touchArea.cpp: In member function 'int touchArea::addTouchArea(long int, long int, long int, long int, char)':
touchArea.cpp:18:29: error: expected primary-expression before '[' token
         while (touchAreaType[counter].used == false && counter < maxTouchArea) counter++;
touchArea.cpp:21:30: error: expected unqualified-id before '[' token
                 touchAreaType[counter].used = true;
touchArea.cpp:22:30: error: expected unqualified-id before '[' token
                 touchAreaType[counter].Id = Id;
touchArea.cpp:23:30: error: expected unqualified-id before '[' token
                 touchAreaType[counter].x1 = x1;
touchArea.cpp:24:30: error: expected unqualified-id before '[' token
                 touchAreaType[counter].y1 = y1;
touchArea.cpp:25:30: error: expected unqualified-id before '[' token
                 touchAreaType[counter].x2 = x2;
touchArea.cpp:26:30: error: expected unqualified-id before '[' token
                 touchAreaType[counter].y2 = y2;
C:\Users\Flo\AppData\Local\Temp\arduino_build_130905\sketch\touchArea.cpp: In member function 'bool touchArea::removeTouchArea(char)':
touchArea.cpp:33:28: error: expected primary-expression before '[' token
         while(touchAreaType[counter].Id != Id && counter < maxTouchArea) counter++;
touchArea.cpp:34:25: error: expected primary-expression before '[' token
         if(touchAreaType[counter].Id == Id) touchAreaType[counter].used = false; return 1;
touchArea.cpp:34:58: error: expected unqualified-id before '[' token
touchArea.cpp:35:9: error: 'else' without a previous 'if'
         else return 0;
C:\Users\Flo\AppData\Local\Temp\arduino_build_130905\sketch\touchArea.cpp: In member function 'bool touchArea::removeTouchArea(int)':
touchArea.cpp:39:22: error: expected unqualified-id before '[' token
         touchAreaType[Id].used = false;
C:\Users\Flo\AppData\Local\Temp\arduino_build_130905\sketch\touchArea.cpp: In member function 'char touchArea::gettouchArea(long int, long int)':
touchArea.cpp:46:43: error: expected primary-expression before '[' token
                 if(isBetween(touchAreaType[counter].x1, x, touchAreaType[counter].x2) && isBetween(touchAreaType[counter].y1, y, touchAreaType[counter].y2)) {
touchArea.cpp:46:73: error: expected primary-expression before '[' token
touchArea.cpp:46:113: error: expected primary-expression before '[' token
touchArea.cpp:46:143: error: expected primary-expression before '[' token
touchArea.cpp:47:45: error: expected primary-expression before '[' token
                         return touchAreaType[counter].Id;
Der Code befindet sich im Anhang
Viele Grüße,
Flo
touchArea.cpp (1.89 KB)
touchArea.h (548 Bytes)
Fehler.txt (18.9 KB)
'touchAreaType' ist kein Array. Aus deinem Code:
typedef struct
        long x1, y1, x2, y2;
        char Id;
        bool used;
touchAreaType;
Du wolltest wahrscheinlich 'TouchAreas' verwenden.
LightuC:
UPS
GLS :slight_smile:
Netter Fehler!
