expected primary-expression before ')' token
I am trying to create a time interval that each section displays to the serial monitor and my LCD screen using the millis() command, but I keep getting this error code. I am a newbie with Arduino coding.
This is a demo for the Adafruit MCP9808 breakout
----> http://www.adafruit.com/products/1782
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
#include <Wire.h>
#include "Adafruit_MCP9808.h"
// Create the MCP9808 temperature sensor object
Adafruit_MCP9808 tempsensor = Adafruit_MCP9808();
#include <Wire.h>
#include "Adafruit_SI1145.h"
Adafruit_SI1145 uv = Adafruit_SI1145();
// include the library code:
#include <LiquidCrystal.h>
#include <Encoder.h>
Encoder myEnc(2, 3);
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = 7, en = 8, d4 = 9, d5 = 10, d6 = 11, d7 = 12;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
unsigned long previousMillisEN = 0;
unsigned long previousMillisTemp = 0;
unsigned long previousMillisEnd = 0;
unsigned long previousMillisUV = 0;
#define temp 1000;
#define UV 1000;
#define ending 5000;
#define R_C 0.031416;
void print_time(unsigned long time_millis);
  while (!Serial); //waits for serial terminal to be open, necessary in newer arduino boards.
  Serial.println("Adafruit MCP9808");
  // Make sure the sensor is found, you can also pass in a different i2c
  // address with tempsensor.begin(0x19) for example, also can be left in blank for default address use
  // Also there is a table with all addres possible for this sensor, you can connect multiple sensors
  // to the same i2c bus, just configure each sensor with a different address and define multiple objects for that
  //  A2 A1 A0 address
  //  0  0  0   0x18  this is the default address
  //  0  0  1   0x19
  //  0  1  0   0x1A
  //  0  1  1   0x1B
  //  1  0  0   0x1C
  //  1  0  1   0x1D
  //  1  1  0   0x1E
  //  1  1  1   0x1F
  if (!tempsensor.begin(0x18)) {
    Serial.println("Couldn't find MCP9808! Check your connections and verify the address is correct.");
    while (1);
  tempsensor.setResolution(0); // sets the resolution mode of reading, the modes are defined in the table bellow:
  // Mode Resolution SampleTime
  //  0    0.5°C       30 ms
  //  1    0.25°C      65 ms
  //  2    0.125°C     130 ms
  //  3    0.0625°C    250 ms
  Serial.println("Adafruit SI1145");
  if (! uv.begin(0x60)) {
    Serial.println("Didn't find Si1145");
    while (1);
  Serial.println("OK!");
long oldPosition  = -999;
  int AnSpeed;
  int Speed;
  tempsensor.wake();   // wake up, ready to read!
  // Read and print out the temperature, also shows the resolution mode used for reading.
  Serial.println (tempsensor.getResolution());
  float c = tempsensor.readTempC();
  if(millis() >= previousMillisTemp + temp){
     previousMillisTemp +=temp;
     print_time(previousMillisTemp);
     Serial.print("Temp: ");
     Serial.print(c, 1); Serial.print("*C");
  tempsensor.shutdown_wake(1); // shutdown MSP9808 - power consumption ~0.1 mikro Ampere, stops temperature sampling
  Serial.println("");
  if(millis() >= previousMillisUV + UV){
     previousMillisUV +=UV;
     print_time(previousMillisUV);
     Serial.print("Vis: "); Serial.println(uv.readVisible());
     Serial.print("IR: "); Serial.println(uv.readIR());
  // Uncomment if you have an IR LED attached to LED pin!
  //Serial.print("Prox: "); Serial.println(uv.readProx());
  float UVindex = uv.readUV();
  // the index is multiplied by 100 so to get the
  // integer index, divide by 100!
  UVindex /= 100.0;
  Serial.print("UV: ");  Serial.println(UVindex);
  float newPosition = myEnc.read();
  AnSpeed = ((R_C*newPosition)-(R_C*oldPosition))/(currentMillisEN - previousMillisEN);
  Speed = AnSpeed*(0.01);
  previousMillisEN = currentMillisEN;
  if (newPosition != oldPosition) {
    oldPosition = newPosition;
    Serial.println(newPosition);
    // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
     lcd.print("T: "); lcd.print(c, 1); lcd.print("*C");
  if(millis() >= (previousMillisUV + UV)){
     lcd.setCursor(0, 1);
     lcd.print("UV: "); lcd.print(UVindex);
  lcd.setCursor(9, 1);
  lcd.print("V: "); lcd.print(Speed);
This is the error that I get.
Arduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board: "Arduino Uno"
C:\Users\justi\OneDrive\Desktop\ENGG-160\Codes\Weather_Station_Code\Weather_Station_Code.ino: In function 'void loop()':
Weather_Station_Code:102:43: error: expected primary-expression before ')' token
Weather_Station_Code:111:39: error: expected primary-expression before ')' token
Weather_Station_Code:43:21: error: expected ')' before ';' token
C:\Users\justi\OneDrive\Desktop\ENGG-160\Codes\Weather_Station_Code\Weather_Station_Code.ino:128:15: note: in expansion of macro 'R_C'
Weather_Station_Code:128:19: error: invalid type argument of unary '*' (have 'float')
Weather_Station_Code:128:37: error: invalid type argument of unary '*' (have 'long int')
Weather_Station_Code:130:22: error: 'currentMillisEN' was not declared in this scope
C:\Users\justi\OneDrive\Desktop\ENGG-160\Codes\Weather_Station_Code\Weather_Station_Code.ino:130:22: note: suggested alternative: 'previousMillisEN'
                      previousMillisEN
Weather_Station_Code:140:43: error: expected primary-expression before ')' token
Weather_Station_Code:40:16: error: expected ')' before ';' token
 #define UV 1000;
C:\Users\justi\OneDrive\Desktop\ENGG-160\Codes\Weather_Station_Code\Weather_Station_Code.ino:145:38: note: in expansion of macro 'UV'
 #define UV 1000;
Weather_Station_Code:145:40: error: expected primary-expression before ')' token
exit status 1
Please help! I do not understand what I am doing wrong here. Thank you.
#define R_C 0.031416; ‘do not use’ the ; when using #define
use this format:
if(millis() - previousMillisTemp >= temp)
This one seems obvious to me:
And something like that for newPosition.
larryd:
use this format:
This fixed that issue, but now it gives me this which solutions online seemed to not fix.
C:\Users\justi\AppData\Local\Temp\ccpLiT0o.ltrans0.ltrans.o: In function `loop':
C:\Users\justi\OneDrive\Desktop\ENGG-160\Codes\Weather_Station_Code/Weather_Station_Code.ino:104: undefined reference to `print_time(unsigned long)'
C:\Users\justi\OneDrive\Desktop\ENGG-160\Codes\Weather_Station_Code/Weather_Station_Code.ino:113: undefined reference to `print_time(unsigned long)'
C:\Users\justi\OneDrive\Desktop\ENGG-160\Codes\Weather_Station_Code/Weather_Station_Code.ino:142: undefined reference to `print_time(unsigned long)'
C:\Users\justi\OneDrive\Desktop\ENGG-160\Codes\Weather_Station_Code/Weather_Station_Code.ino:147: undefined reference to `print_time(unsigned long)'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Uno.
1:
That means: check line 104 of your Weather_Station_Code.ino.
2: Line 104 says:
No problem there.
3: But
undefined reference to 'print_time()'
means the compiler cannot find that function. Can you?
Erik_Baas:
1:
2: Line 104 says:
No problem there.
3: But
I ended up taking out all the millis() commands and just having the serial monitor and LCD screen update quickly. Thanks for the support!
slanthand:
Of course, just delete all code that's doesn't work and/or gives error messages that need reading. Now why didn't I think of that?
