Expected primary-expression before "<=" token
NEW TO ARDUINO AND FORUM:
I don't understand what the phrase 'Expected primary-expression' means. My web search didn't help... I'm new to Arduino and this language.
int yelLed=6;
int redLed=9;
int yelTime=500;
int redTime=500;
int yelBlink=3;
int redBlink=5;
int j;
// put your setup code here, to run once: {
pinMode(yelLed,HIGH);
pinMode(redLed,HIGH);
// put your main code here, to run repeatedly: {
for(j=1;<=yelBlink;j=j+1) {
digitalWrite(yelLed,HIGH);
delay(yelTime);
digitalWrite(yelLed,LOW);
delay(yelTime);
for(j=1;<=redBlink;j=j+1) {
digitalWrite(redLed,HIGH);
delay(redTime);
digitalWrite(redLed,LOW);
delay(redTime); }
ERROR COMMENT:
In function 'void loop()':
Blink_Yel_Red_Long:19:9: error: expected primary-expression before '<=' token
for(j=1;<=yelBlink;j=j+1){
Blink_Yel_Red_Long:27:10: error: expected primary-expression before '<=' token
for(j=1;<=redBlink;j=j+1){
exit status 1
Did you try for(int j=1;<=yelBlink; j++)?
for(j=1;xxxx<=yelBlink;j=j+1) {
It means there's something missing where I marked the xxxx above.
Compare yours to this from the ref man:
for (int i = 0; i <= 255; i++) {
Both of these solutions worked to remove the error message. Oddly, even with the error message, the program still ran the LEDs as intended. ???
Hello
What is the intendition?
If the compile fails, the upload is not attempted, and the Arduino is left running the previously loaded sketch.
