Hello all, I am extremely new to Arduinos, and I ran into this issue with my code, what should I do?
#include <Keypad.h>
#include <Joystick.h>
#define ENABLE_PULLUPS
#define NUMROTARIES 4
#define NUMBUTTONS 32
#define NUMROWS 4
#define NUMCOLS 6
byte buttons[NUMROWS][NUMCOLS] = {
{0,1,2,3,4,5},
{6,7,8,9},
{10,11,12,13,14,15}, void setup() {
{15,16,17,18,19},
{20,21,22,23},
struct rotariesdef {
byte pin1;
byte pin2;
int ccwchar;
int cwchar;
volatile unsigned char state;
rotariesdef rotaries[NUMROTARIES] {
{0,1,24,25,0},
{2,3,26,27,0},
{4,5,28,29,0},
{6,7,30,31,0},
#define DIR_CCW 0x10
#define DIR_CW 0x20
#define R_START 0x0
#ifdef HALF_STEP
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttable[6][4] = {
// R_START (00)
{R_START_M, R_CW_BEGIN, R_CCW_BEGIN, R_START},
// R_CCW_BEGIN
{R_START_M | DIR_CCW, R_START, R_CCW_BEGIN, R_START},
// R_CW_BEGIN
{R_START_M | DIR_CW, R_CW_BEGIN, R_START, R_START},
// R_START_M (11)
{R_START_M, R_CCW_BEGIN_M, R_CW_BEGIN_M, R_START},
// R_CW_BEGIN_M
{R_START_M, R_START_M, R_CW_BEGIN_M, R_START | DIR_CW},
// R_CCW_BEGIN_M
{R_START_M, R_CCW_BEGIN_M, R_START_M, R_START | DIR_CCW},
#else
#define R_CW_FINAL 0x1
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] = {
// R_START
{R_START, R_CW_BEGIN, R_CCW_BEGIN, R_START},
// R_CW_FINAL
{R_CW_NEXT, R_START, R_CW_FINAL, R_START | DIR_CW},
// R_CW_BEGIN
{R_CW_NEXT, R_CW_BEGIN, R_START, R_START},
// R_CW_NEXT
{R_CW_NEXT, R_CW_BEGIN, R_CW_FINAL, R_START},
// R_CCW_BEGIN
{R_CCW_NEXT, R_START, R_CCW_BEGIN, R_START},
// R_CCW_FINAL
{R_CCW_NEXT, R_CCW_FINAL, R_START, R_START | DIR_CCW},
// R_CCW_NEXT
{R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
#endif
byte rowPins[NUMROWS] = {21,20,19,18,15};
byte colPins[NUMCOLS] = {14,16,10,9,8};
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
Joystick.begin();
rotary_init();}
CheckAllEncoders();
CheckAllButtons();
void CheckAllButtons(void) {
if (buttbx.getKeys())
for (int i=0; i<LIST_MAX; i++)
if ( buttbx.key*.stateChanged ) *
_ switch (buttbx.key*.kstate) { _
_ case PRESSED:_
_ case HOLD:_
_ Joystick.setButton(buttbx.key.kchar, 1);
case RELEASED:
case IDLE:
Joystick.setButton(buttbx.key.kchar, 0);
void rotary_init() {
for (int i=0;i<NUMROTARIES;i++) {
pinMode(rotaries.pin1, INPUT);
pinMode(rotaries.pin2, INPUT);_
#ifdef ENABLE_PULLUPS*
_ digitalWrite(rotaries*.pin1, HIGH);
digitalWrite(rotaries.pin2, HIGH);
#endif*
}_
unsigned char rotary_process(int _i) {
unsigned char pinstate = (digitalRead(rotaries[i].pin2) << 1) | digitalRead(rotaries[i].pin1);
rotaries[i].state = ttable[rotaries[i].state & 0xf][pinstate];
return (rotaries[i].state & 0x30);*
void CheckAllEncoders(void) {
* for (int i=0;i<NUMROTARIES;i++) {_
unsigned char result = rotary_process(i);
if (result == DIR_CCW) {
Joystick.setButton(rotaries_.ccwchar, 1); delay(50); Joystick.setButton(rotaries.ccwchar, 0);
};_
if (result == DIR_CW) {
Joystick.setButton(rotaries_.cwchar, 1); delay(50); Joystick.setButton(rotaries.cwchar, 0);
}*_
