Expected primary-expression before
bprime [i, j] andx[i] it is array
In theoretical chaos it is a logistic function
Can we cut out the middleman here, and just see the original MATLAB code?
x (1) the initial condition of the system
x (i) the logistic function
so obviously MatLab code is not C.
yes it is matlab I try to translate to C
It also appears that MATLAB arrays index from 1, not 0
yes it is
Hi.
This video is about converting matlab code to C code.
See if it helps.
RV mineirin
Thank you mr. I will watch it
The binarisation code looks like it could be a lot simpler - you certainly should not be using pow()
I do not know . I only know some basics in Arduino so I try to use pow ()
Well, don't - it isn't suitable
so how i should do for (a>=1/(2^k)) ?
2^k in MATLAB raises 2 to the power k.
In C++, you could write it 1 << k, for non-negative integer values of k
ok thank you
