Expected primary expression expected before ")" token
I’m trying to build a temperature sensor that records its information to a micro-SD card. This error message keeps popping up, no matter what I change. I’ve looked through other forums, but can’t figure it out. Any help would be appreciated!
rocket.ino (2.74 KB)
Can I suggest you review how to write a for loop?
(deleted)
(deleted)
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
sketch_may03a:91: error: expected primary-expression before ')' token
   for (int temperaturePin = 0;) {
sketch_may03a:91: error: expected ';' before ')' token
That's telling you that the 'if' in line 91 is missing a semicolon before the close-paren.
sketch_may03a:97: error: a function-definition is not allowed here before '{' token
That's telling you that in line 97 you are trying to define a function inside a function. That usually means you forgot a '}' in the previous function.
sketch_may03a:132: error: expected '}' at end of input
That's telling you that there is a '}' missing in the last function in the file.
