expected unqualified-id before 'if'
hi,
I have some problems with programming. Would you guys help me with this problem.
#include <Time.h>
#include <Wire.h>
#include <DS1307RTC.h> // a basic DS1307 library that returns time as a time_t
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
char val; // variable to receive data from the serial port
const int switchPin = 6;
int switchState = 0;
int prevSwitchState = 0;
int reply;
lcd.begin(16, 2);{
pinMode(switchPin, INPUT);
pinMode(10, OUTPUT);
void loop(){
if( Serial.available() ) // if data is available to read
val = Serial.read(); // read it and store it in ‘val’
if (val == ‘a’ )
digitalClockDisplay();
void digitalClockDisplay(){
// digital clock display of the time
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.print(" “);
Serial.print(day());
Serial.print(” “);
Serial.print(month());
Serial.print(” ");
Serial.print(year());
lcd.setCursor(2, 0); // Set LCD cursor position (column, row)
lcd.print(hour());
lcd.print(":");
lcd.print (minute());
lcd.print(":");
lcd.print(second());
lcd.print(" “);
lcd.print(”");
lcd.setCursor(3, 1); // Set LCD cursor position (column,row)
lcd.print(day());
lcd.print(".");
lcd.print(month());
lcd.print(".");
lcd.print(year());
// Print text to LCD
// Delay to read text
// Clear the display
void printDigits(int digits){
// utility function for digital clock display: prints preceding colon and leading 0
Serial.print(":");
if(digits < 10)
Serial.print(‘0’);
Serial.print(digits);
Serial.println(“geen gevaar”);
if( val ==‘z’ )
buzz(10, 700, 500);
void buzz(int targetPin, long frequency, long length) {
long delayValue = 1000000/frequency/2;
long numCycles = frequency * length/ 1000;
for (long i=0; i < numCycles; i++){
digitalWrite(targetPin,HIGH);
delayMicroseconds(delayValue);
digitalWrite(targetPin,LOW);
switchState = digitalRead(switchPin);
if (switchState != prevSwitchState) {
if (switchState == LOW) {
lcd.clear();
lcd.setCursor(0,0);
lcd.print("! Overstroming !");
lcd.setCursor(4, 1);
switch(reply) {
case 0:
lcd.print(“Ga naar”);
delay(3000);
case 1:
lcd.print(“marktplein”);
delay(3000);
case 2:
lcd.print("te Veurne ");
delay(3000);
prevSwitchState = switchState;
Serial.println(“gevaar”);
  lcd.begin(16, 2);{
Why is that curly brace there?
If there is data to read, do nothing. Otherwise, no nothing. Why?
  val = Serial.read();         // read it and store it in 'val'
Even if there isn't any. Why?
if( val =='z' )
buzz(10, 700, 500);
You can't have code that is not in a function.
I'm new in the ArduinoWorld so i taked some things from site and putted them together and became this . I would like to Communicate with my tablet and display the wordt between this ''.
There is a Nederland section in the International area if you would be more comfortable in there?
