expected unqualified-id before 'if'
const int temp_trans_pin = A0 , Heater_pin = 8, FAN_pin = 6;
/*FAN_pin: here I used DC motor instead of FAN because I couldn't find the symbol for it.Similarly, for the Heater (Heater_pin), I used LED.*/
//Set the range of desired temperature
float MinTemp = 20, MaxTemp = 25;/*Room temperature is [20,25] degree C*
  // Include The LCD library code
  #include <LiquidCrystal.h>
  //Initialize the library with the numbers of the interface pins
  LiquidCrystal LCD (12, 11, 5, 4, 3, 2);
    //Sysytem Initialization
    LCD.begin(16, 2);
    pinMode (Heater_pin, OUTPUT);// LED in our case
    pinMode (FAN_pin, OUTPUT);
    // Display the desired range of temperature
    LCD.print("Room Temperature(C):");
    LCD.setCursor (2,1);
    LCD.print (MinTemp); LCD.print("-");LCD.print (MaxTemp);
    delay (2000)
  void loop(){
    float Eqv_volt, SensorTemp;
    //Read voltage and convert to temperature (Celcius)
    Eqv_volt = analogRead(temo_trans_pin) *5.0 / 1023;
    SensorTemp = 100.0 * Eqv_volt-50.0;
    // Display the sensor reading
    LCD.clear();
    LCD.print("Sensor reading:");
    LCD.setCursor(2,1);
    LCD.print(SensorTemp);LCD.print("C");
    delay(2000)
    /*Compare the sensor reading with the range of acceptable temperature*/
if (SensorTemp > MaxTemp) {
  LCD.clear();
  LCD.print ("Temp is Higher!");//higher than the max
  /*Turn on FAN (DC Motor)! to regulate the temp.
    Increase FAN speed at slow rate*/
  LCD.setCursor(0, 1); LCD.print("Turn On Fan!");
  for (int i = 0; i <= 255; i ++) {
    analogWrite (FAN_pin, i);
  delay(2000)
else if (SensorTemp < MinTempt) {
  LCD.clear();
  LCD.print("Temp is LOWER!");//Less than the mini
  LCD.print("Turn on Heater");
  //Turn on the heater, LED in our case
  digitalWrite(Heater_pin, HIGH);
  delay(3000)
else if (SensorTemp > MinTemp && SensorTemp < MaxTemp) {
  /*Now Temperature is Perfect.That is, it is in the desired range. Hence no need changes!!*/
  LCD.clear();
  LCD.print("Temp is NORMAL!");
  LCD.setCursor(2, 1);
  LCD.print("Turn Off All !");
  LCD.clear()
else {
  LCD.clear();
  LCD.Print("Something went");
  LCD.print("WRONG in the CKT");
  LCD.clear()
expected unqualified-id before 'if' at coding below
.. HELP
LCD.clear();
/Turn on FAN (DC Motor)! to regulate the temp.
delay(2000)
    delay(2000)
Missing semi-colon.
In future, please copy the error message in full from the IDE and paste it between code tags in your post. There is a small button on the IDE to copy the complete error message.
