expected unqualified-id before numeric constant !!!
Hello Cmmunity,
This is my first post cause I can't find solution to my problem !
Some syntax problem with the if cause Arduino say me :
This is my code :
const int pingPin = 7;
const int WaterPin=7;//Pour détecter l'eau
const int pompe=12;//Pour controller la pompe
  pinMode(pompe,OUTPUT);
  long duration, cm;
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  cm = microsecondsToCentimeters(duration);
  Serial.print(cm);
  Serial.print("cm");
  delay(100);
long microsecondsToCentimeters(long microseconds)
  return microseconds / 29 / 2;
    if (cm <= 5)  {
    // On allume la pompe
    digitalWrite(pompe, HIGH);
  } else if (cm >= 15) {
    // On éteint la pompe
    digitalWrite(pompe, LOW);
  }  else   {
Thanks a lot !
Raphael.
    if (cm <= 5)  {
  }  else   {
Is that code meant to be in loop?
Yes !
I just beggin...
raphael753:
I just beggin...
I don't understand. Does that mean you need more help?
No that's good !
Thanks a lot !
So now you know keeping good indentation can actually solve or avoid problems :slight_smile:
Just remember the magic keys: CTRL+T
