expected unqualified-id before numeric constant
const int potential = 0 // pin number of the potentiometer
pinMode(potential, INPUT); //initialize the potentiometer pin as an input
Serial.begin(9600); //serial start
{ //looopy
int numba1; //declare integer baybayyyyy
int numba2;
numba1 = analogRead(potential); //reads potentiometer yeilds (0 through 1023)
delay(1000); //let value save
numba2 = analogRead(potential); //reads potentiometer yeilds (0 through 1023)
//Serial.println(numba1); //return potentiometer value
//Serial.println(numba2); //return potentiometer value
int finalnumba;
finalnumba = (numba1-numba2);
// boolean threshold; //true or false
int sensitivity;
sensitivity = 10; //low number makes it very sensitive, high number makes it non-sensitive
// int num;
// num = finalnumba; //make it easier to type (doesn’t really change much)
if (abs(finalnumba)>sensitivity)
if (finalnumba < 0) // trying to make multiple turns easier
Serial.println(“increased value”);
if (finalnumba > 0)
Serial.println(“decreased value”);
Serial.println(" ");
I get this error and I can’t quite seem to fix it:
“error: expected unqualified-id before numeric constantBad error line: -2”
Thanks for any help :slight_smile:
You forgot to add a semicolon in the first line.
const int potential = 0[glow];[/glow] // pin number of the potentiometer
{ //looopy
  int numba2;
  int finalnumba;
  int sensitivity;
  // int num;
  // num = finalnumba; //make it easier to type (doesn't really change much)
      Serial.println("increased value");
    if (finalnumba > 0)
      Serial.println("decreased value");
Lefty
thanks retrolefty :)
I'm also trying to send a command to a computer game when certain conditions are met, would this be possible through the serial commands?
"Command"? Like one ore more keystrokes? Like executing a menu item? Like a mouse click?
A keystroke or a click would do lovely, I have both a mouse and a keyboard I can gut if needbe.
Mimic a PS/2 Keyboard... http://www.arduino.cc/playground/Main/PS2Keyboard http://www.arduino.cc/playground/Main/PS2KeyboardExt
Various discussions... http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1193702598 http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1262655256 http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1252536737
Arduino as an HID device... http://www.pjrc.com/teensy/teensyduino.html http://code.rancidbacon.com/ProjectLogArduinoUSB
There are some good suggestions here... http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1258067608
Gobetwino has been suggested many times.
