Expected unqualified-id before '{' token light pattern
hi I’m new to the program and all that I’m getting the error: expected unqualified-id before ‘{’ token
so I put this code in. sorry it’s long.
void blink_15()
int t = 80;
digitalWrite(led1, HIGHigitalWrite(led1, LOW);
digitalWrite(led2, HIGH);
digitalWrite(led2, LOW);
digitalWrite(led3, HIGH);
delay(t);
digitalWrite(led3, LOW);
digitalWrite(led4, HIGH);
digitalWrite(led10, HIGH);
delay(t);
digitalWrite(led4, LOW);
digitalWrite(led10, LOW);
digitalWrite(led5, HIGH);
digitalWrite(led9, HIGH);
delay(t);
digitalWrite(led5, LOW);
digitalWrite(led9, LOW);
digitalWrite(led6, HIGH);
digitalWrite(led8, HIGH);
delay(t);
digitalWrite(led6, LOW);
digitalWrite(led8, LOW);
delay(t);
digitalWrite(led7, HIGH);
delay(t);
digitalWrite(led7, LOW);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
digitalWrite(led1, HIGH);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
so I put a space before ‘{’ and I still get the error
When you declare a function, the ‘{’ that starts the body of the function goes AFTER the ‘)’ that ends the argument list of the function.
ok I’ll give it a try
ok it work for all but one in a whole code and that one says error: a function-definition is not allowed here before ‘{’ token
Sounds like you have another ‘{’ or ‘}’ in the wrong place. You can’t have a function defined inside a function so if a function has too many ‘{’ or too few ‘}’ the next function will be inside it and generate an error.
Exactly why you should not post a SNIPPET OF CODE. You need to post your full code, as you may have multiple errors that need looking into. :slight_smile:
ive got over 2k lines of code
but ok here you are
int led0 = 1;
int led1 = 3;
int led2 = 5;
int led3 = 7;
int led4 = 9;
int led5 = 11;
int led6 = 13;
int led7 = 15;
int led8 = 17;
int led9 = 19;
int led10 = 21;
  pinMode(led0, OUTPUT);
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  pinMode(led4, OUTPUT);
  pinMode(led5, OUTPUT);
  pinMode(led6, OUTPUT);
  pinMode(led7, OUTPUT);
  pinMode(led8, OUTPUT);
  pinMode(led9, OUTPUT);
  pinMode(led10, OUTPUT);
/////////////pattern 1///////////////////////////////////////////////////////////////////////////////////////////////////
void blink_1()
  int t = 80;
  digitalWrite(led1, HIGH );
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  digitalWrite(led1, LOW );
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  digitalWrite(led1, LOW);
  delay(t);
/////////////pattern 2///////////////////////////////////////////////////////////////////////////////////////////////////
void blink_2()
  int t = 80;
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
/////////////pattern 3///////////////////////////////////////////////////////////////////////////////////////////////////
void blink_3()
  int t = 150;
  delay(t);
  delay(t);
  delay(t);
/////////////pattern 4///////////////////////////////////////////////////////////////////////////////////////////////////
void blink_4()
  int t = 80;
  delay(t);
  delay(t);
  delay(t);
  digitalWrite(led2, LOW );
  delay(t);
  digitalWrite(led3, LOW );
  delay(t);
  digitalWrite(led4, LOW );
  delay(t);
  digitalWrite(led5, LOW );
  delay(t);
  digitalWrite(led6, LOW );
  delay(t);
  digitalWrite(led7, LOW );
  delay(t);
  digitalWrite(led8, LOW );
  delay(t);
  digitalWrite(led9, LOW );
  delay(t);
  digitalWrite(led10, LOW );
  delay(t);
/////////////pattern 5///////////////////////////////////////////////////////////////////////////////////////////////////
void blink_5()
  int t = 70;
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
/////////////pattern 6///////////////////////////////////////////////////////////////////////////////////////////////////
void blink_6()
  int t = 70;
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
/////////////pattern 7///////////////////////////////////////////////////////////////////////////////////////////////////
void blink_7()
  int t = 60;
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  /////////////pattern 8///////////////////////////////////////////////////////////////////////////////////////////////////
void blink_10()
int t = 100;
  digitalWrite(led12, HIGH);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
/////////////pattern 9///////////////////////////////////////////////////////////////////////////////////////////////////
void blink_10()
int t = 80;
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  (led10, LOW );
  delay(t);
  digitalWrite(led11, LOW );
  delay(t);
  digitalWrite(led12, LOW );
  delay(t);
  digitalWrite(led13, LOW );
  delay(t);
  digitalWrite(led13, HIGH );
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
/////////////pattern 10///////////////////////////////////////////////////////////////////////////////////////////////////
  void blink_12()
  int t = 80;
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  (led9, LOW );
  delay(t); (led10, LOW);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  lay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
/////////////pattern 11///////////////////////////////////////////////////////////////////////////////////////////////////
  void blink_13()
  int t = 90;
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  digitalWrite(led6, HIGH );
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
/////////////pattern 12///////////////////////////////////////////////////////////////////////////////////////////////////
void blink_14()
  int t = 80;
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
/////////////pattern 13///////////////////////////////////////////////////////////////////////////////////////////////////
void blink_15()
  int t = 80;
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
delay(t);
Well the braces are mainly wrong on all the functions, you use led11,12,13 etc which you haven’t declared, you have some functions duplicated, etc etc.
function definitions should look like:
void blah ()
Fix these structural problems first - auto-indent may help you find them. In C and C++ you cannot nest function declarations (its a limitation of the language).
You probably need to learn about arrays and data-driven programming so you can greatly
shorten and simplify your code too, but get it working first :slight_smile:
If you use an array of LED pin numbers and loops, your sketch would be WAY shorter and easier to maintain.
Here is your sketch with a BUNCH of typos fixed:
int led0 = 1;
int led1 = 3;
int led2 = 5;
int led3 = 7;
int led4 = 9;
int led5 = 11;
int led6 = 13;
int led7 = 15;
int led8 = 17;
int led9 = 19;
int led10 = 21;
void blink_1()
  int t = 80;
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
void blink_2()
  int t = 80;
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
void blink_3()
  int t = 150;
  delay(t);
  delay(t);
  delay(t);
void blink_4()
  int t = 80;
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
void blink_5()
  int t = 70;
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
void blink_6()
  int t = 70;
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
void blink_7()
  int t = 60;
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
void blink_10()
  int t = 100;
  // digitalWrite(led12, HIGH);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
void blink_10A()
  int t = 80;
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  // digitalWrite(led11, LOW );
  delay(t);
  // digitalWrite(led12, LOW );
  delay(t);
  // digitalWrite(led13, LOW );
  delay(t);
  // digitalWrite(led13, HIGH );
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
void blink_12()
  int t = 80;
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
void blink_13()
  int t = 90;
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
void blink_14()
  int t = 80;
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
void blink_15()
  int t = 80;
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
  delay(t);
I hope @dartnashon sticks with programming and comes back to marvel at this one day. :wink:
I also hope s/he is being paid by the lines of code produced!
a7
Here is what your sketch looks like with the first three patterns converted to arrays and loops. It is 84 lines long. Your original sketch through the first three patterns is 292 lines.
const int LEDCount = 11;
const byte LEDPins[LEDCount] = {1, 3, 5, 7, 9, 11, 13, 15, 17, 19, 21};
int PatternDelay = 80;
  for (int i = 0; i < LEDCount; i++)
    pinMode(LEDPins[i], OUTPUT);
void turnAllOff()
    digitalWrite(LEDPins[i], LOW );
void blink_1()
  // Turn each ON in turn
    digitalWrite(LEDPins[i], HIGH );
    delay(PatternDelay);
  // Turn each OFF in turn
void blink_2()
  // Turn each one on briefly in turn
    digitalWrite(LEDPins[1], HIGH);
    digitalWrite(LEDPins[1], LOW);
void blink_3()
  for (int repeat = 0; repeat < 3; repeat++)
    // Odds ON
    for (int i = 1; i < LEDCount; i += 2)
    // Evens OFF
    for (int i = 0; i < LEDCount; i += 2)
      digitalWrite(LEDPins[i], LOW);
    delay(150);
    // Odds OFF
    // Evens ON
      digitalWrite(LEDPins[i], HIGH);
    delay(150);
  turnAllOff();
