Hi everyone.
The sketch got error of: expected unqualified-id before '->' token
how to fix please?
Thanks
Adam
TFT_eSPI display;
int gpsDataBJ = 1;
display.begin();
display.setRotation(1);
display.fillScreen(0);
display.setCursor(0, 0, 2);
display.setTextColor(TFT_WHITE, TFT_BLACK);
display.setTextSize(1);
/// gps = new GPS(GPS_SERIAL, GPS_TX, GPS_RX);
GPS->begin(GPS_BAUD);
Serial.printf("%s\n", GPS->get_fix().toString().c_str());
if (int gpsDataBJ == 1 ) {
Serial.printf(GPS->get_fix().toString().c_str());
display.println(GPS->get_fix().toString().c_str());
display.printf("Tracking %d of %d visible\n", GPS->get_tracking_satellites(), GPS->get_visibile_satellites());
display.printf("Status: %s\n", GPS->get_status() == 'A' ? "LOCK!" : "SEARCHING...");
display.printf("Time: %s\n", GPS->get_fix().timestamp.toString().c_str());
display.printf("Lat: %f\n", GPS->get_fix().latitude);
display.printf("Lng: %f\n", GPS->get_fix().longitude);
display.printf("Speed: %f\n", GPS->get_fix().speed);
display.printf("Almanac: %.1f%% complete\n", GPS->get_fix().almanac.percentComplete());
delay(5000);
ERROR:
Arduino: 1.8.19 (Windows 7), Board: "TTGO LoRa32-OLED V1, 40MHz, 921600, None"
C:\Users\HUA.DELLV-PC\Documents\Arduino\sketch_jan07c\sketch_jan07c.ino: In function 'void setup()':
sketch_jan07c:24:6: error: expected unqualified-id before '->' token
C:\Users\HUA.DELLV-PC\Documents\Arduino\sketch_jan07c\sketch_jan07c.ino: In function 'void loop()':
sketch_jan07c:30:28: error: expected primary-expression before '->' token
sketch_jan07c:31:7: error: expected primary-expression before 'int'
sketch_jan07c:31:7: error: expected ')' before 'int'
sketch_jan07c:34:22: error: expected primary-expression before '->' token
sketch_jan07c:35:24: error: expected primary-expression before '->' token
sketch_jan07c:38:54: error: expected primary-expression before '->' token
sketch_jan07c:38:86: error: expected primary-expression before '->' token
sketch_jan07c:39:39: error: expected primary-expression before '->' token
sketch_jan07c:40:37: error: expected primary-expression before '->' token
sketch_jan07c:41:36: error: expected primary-expression before '->' token
sketch_jan07c:42:36: error: expected primary-expression before '->' token
sketch_jan07c:43:38: error: expected primary-expression before '->' token
sketch_jan07c:44:53: error: expected primary-expression before '->' token
exit status 1
option enabled in File -> Preferences.
shanren:
Looks like you are missing an include of the GPS library ? Probably one for the TFT display also.
You have already declared this variable so you don't need int
again.
Thank you red_car.
I modified the two places and got the same error.
#include <TFT_eSPI.h>
#include <GPS.h>
TFT_eSPI display;
int gpsDataBJ = 1;
display.begin();
if (gpsDataBJ == 1 ) {
delay(5000);
C:\Users\HUA.DELLV-PC\Documents\Arduino\main_cpp_test\main_cpp_test.ino: In function 'void setup()':
main_cpp_test:27:6: error: expected unqualified-id before '->' token
C:\Users\HUA.DELLV-PC\Documents\Arduino\main_cpp_test\main_cpp_test.ino: In function 'void loop()':
main_cpp_test:33:28: error: expected primary-expression before '->' token
main_cpp_test:37:22: error: expected primary-expression before '->' token
main_cpp_test:38:24: error: expected primary-expression before '->' token
main_cpp_test:41:54: error: expected primary-expression before '->' token
main_cpp_test:41:86: error: expected primary-expression before '->' token
main_cpp_test:42:39: error: expected primary-expression before '->' token
main_cpp_test:43:37: error: expected primary-expression before '->' token
main_cpp_test:44:36: error: expected primary-expression before '->' token
main_cpp_test:45:36: error: expected primary-expression before '->' token
main_cpp_test:46:38: error: expected primary-expression before '->' token
main_cpp_test:47:53: error: expected primary-expression before '->' token
exit status 1
Where did you get that code?
Try using a "." instead of "->" in the function calls.
Can I suggest you forget the display for the moment and use one of the example codes that came with the GPS library and the IDE Monitor.
This is a good place to start, once you have good GPS readings, then think about your display.
The key here is to develop your code in stages to prove your hardware and interfacing code.
Thanks.. Tom..
I got the code here:
and changed "->" into "." and got new error:
main_cpp_test:33:25: error: 'GPS_get' was not declared in this scope
Serial.printf("%s\n", GPS_get.fix().toString().c_str());
main_cpp_test:37:22: error: expected primary-expression before '.' token
Serial.printf(GPS.get_fix().toString().c_str());
main_cpp_test:38:24: error: expected primary-expression before '.' token
display.println(GPS.get.fix().toString().c_str());
exit status 1
Maybe because you put the "." in the wrong place?
shanren:
GPS_get.fix()
GPS.get_fix()
Thanks.
I got the GPS reading already, and like to have the path shown on a map or even just a blank LCD.
I didn't find any GPS tracker example with display yet.
Thanks.
the GPS.get_fix()
got error of:
main_cpp_test:33:28: error: expected primary-expression before '.' token
Serial.printf("%s\n", GPS.get_fix().toString().c_str());
display.println(GPS.get_fix().toString().c_str());
exit status 1
If you have already got the GPS working then please refer to the code that works to see what is different.
The difference is the code above that try to make path on a display.
Are you still commenting out
a7
shanren:
difference
Nonsense… it is complaining about the GPS code… READ the error.
system
Closed
July 7, 2023, 3:48am
14
