// Include Scheduler since we want to manage multiple tasks. #include <Scheduler.h>
int led1 = 13;
int led2 = 12;
int led3 = 11;
// Setup the 3 pins as OUTPUT
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
// Add "loop2" and "loop3" to scheduling.
// "loop" is always started by default.
Scheduler.startLoop(loop2);
Scheduler.startLoop(loop3);
// Task no.1: blink LED with 1 second delay.
digitalWrite(led1, HIGH);
// IMPORTANT:
// When multiple tasks are running 'delay' passes control to
// other tasks while waiting and guarantees they get executed.
digitalWrite(led1, LOW);
// Task no.2: blink LED with 0.1 second delay.
void loop2() {
digitalWrite(led2, HIGH);
delay(100);
digitalWrite(led2, LOW);
delay(100);
// Task no.3: accept commands from Serial port
// '0' turns off LED
// '1' turns on LED
void loop3() {
if (Serial.available()) {
char c = Serial.read();
if (c=='0') {
digitalWrite(led3, LOW);
Serial.println("Led turned off!");
if (c=='1') {
digitalWrite(led3, HIGH);
Serial.println("Led turned on!");
// IMPORTANT:
// We must call 'yield' at a regular basis to pass
// control to other tasks.
yield();
Arguably, the MOST important part of any compiler error message is the two numbers that tell you EXACTLY WHERE the error was flagged. Why do people keep asking for help, and leaving this vital information out??
RayLivingston:
Regards,
Ray L.
It's almost like some people didn't learn this in school or have years of doing it to know.
But that would be ridiculous!
The delays you have in that code are the opposite of what works well for running multiple tasks.
There are many examples and tutorials showing how to do multiple tasks at once without a black box, errrr, library. If you take the time to go through, learn and mess with the examples then
A) you won't violate what you're supposed to be using.
B) you won't need the library.
The first link at the bottom of my post is to a very good and complete lesson to get people started on the very thing that you want. The second link is further steps that introduce more techniques to take it farther, and not just in processing serial data even though that's the examples and title.
Nick gives the WHY as well as the WHAT and HOW to get you well started.
Once you learn at least enough to ask more specific questions, your time here will benefit you far more.
The code posted, available in Arduino 1.58, can be opened using
File Examples Scheduler MultipleBlinks
Works fine - probably a cut and paste problem or wrong board used by the OP.
I had the same trouble recently.
I solved it by downloading https://github.com/fabriceo/SCoop/archive/master.zip
Adding SchedulerARMAVR.zip to the librairies and including it to the sketch instead of Scheduler.h
