Hi, not sure how to fix this pls help! Error in the line Servo.Write(position_last_set);
#include <Servo.h>
#define SERVO_PIN 9
#define GROUND_JOY_PIN A3 //joystick ground pin will connect to Arduino analog pin A3
#define VOUT_JOY_PIN A2 //joystick +5 V pin will connect to Arduino analog pin A2
#define XJOY_PIN A1 //X axis reading from joystick will go into analog pin A1
Servo myservo ;
#define position_target
int position_target ;
int position_last_set ;
pinMode(VOUT_JOY_PIN, OUTPUT) ; //pin A3 shall be used as output
pinMode(GROUND_JOY_PIN, OUTPUT) ; //pin A2 shall be used as output
digitalWrite(VOUT_JOY_PIN, HIGH) ; //set pin A3 to high (+5V)
digitalWrite(GROUND_JOY_PIN,LOW) ; //set pin A3 to low (ground)
myservo.attach(9);
delay(200);
int joystickXVal = analogRead(XJOY_PIN) ; //read joystick input on pin A1
Serial.print(joystickXVal); //print the value from A1
Serial.println(" = input from joystick"); //print "=input from joystick" next to the value
Serial.print((joystickXVal+520)/10); //print a from A1 calculated, scaled value
Serial.println(" = output to servo"); //print "=output to servo" next to the value
Serial.println() ;
myservo.write((joystickXVal+520)/10); //write the calculated value to the servo
if(position_target) != position_last_set)
position_last_set = position_target;
