expected unqualified-id before ')' token
Hi everyone, just play with Blynk with few days,
I would like to click a button to turn on a led, and a led status will on to show the led is on.
I am success to turn on One Led, but fail to turn on 2 Leds with the error message
'expected unqualified-id before ')' token'
Below are my codes, any problems I missed?
const int btnPin1 = 14;
const int btnPin2 = 12;
WidgetLED() led0(V0);
WidgetLED() led1(V1);
BlynkTimer timer;
// V3 LED Widget represents the physical button state
boolean btnState1 = false;
boolean btnState2 = false;
void buttonLedWidget()
 // Read button
 boolean isPressed1 = (digitalRead(led0) == LOW);
 // If state has changed...
 if (isPressed1 != btnState1) {
   if (isPressed1) {
     led0.off();
     led0.on();
   btnState1 = isPressed1;
   boolean isPressed2 = (digitalRead(led1) == LOW);
 if (isPressed2 != btnState2) {
   if (isPressed2) {
     led1.off();
     led1.on();
   btnState2 = isPressed2;
 // Debug console
 Serial.begin(116200);
 Blynk.begin(auth, ssid, pass);
 // You can also specify server:
 //Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 80);
 //Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8080);
 // Setup physical button pin (active low)
 pinMode(btnPin1, INPUT_PULLUP);
 pinMode(btnPin2, INPUT_PULLUP);
   while (Blynk.connect() == false) {
   // Wait until connected
 timer.setInterval(500L, buttonLedWidget);
 Blynk.run();
 timer.run();
Please read How to use the forum. But the summary here:
  • Use code tags
  • Post the COMPLETE error. Because it DOES point to exactly the location the error occurred :wink:
Please use the code-button (</>, most-left button) to post your code. This way it is much easier to read and to provide help.
This is not valid code. If you are trying to instanciate a WidgetLED, loose the parenthesis after the class name.
Furthermore, I see no includes in your code. How is the compiler supposed to know about the types WidgetLED, BlynkTimer and Blynk?
  // Debug console
I don't see any variables named auth, ssid or pass.
digitalRead accepts a pin number, to read from. You are passing an instance of WidgetLED, this will not work!
LightuC:
Furthermore, I see no includes in your code. How is the compiler supposed to know about the types *WidgetLED*, *BlynkTimer* and *Blynk*?
 // Debug console
I just try the example code from the example library and it is success for one led.
LED example
So I modify the code like above to turn on with 2 leds, but the error is occured.
Thanks for applying code tags.
But as LightuC, your code is incomplete. This is a free forum for help to learn how to program. Don't make us have to search to complete your code :wink:
Also, go over it again and check the differences between your code and the example. And yes, a compiler is picky about random (){}etc :wink:
