Flight logger project, having issues with the code, this is the error:
/Users/Taran/Documents/Arduino/flight_logger/flight_logger.ino: In function 'void loop()':
flight_logger:69:19: error: expected unqualified-id before '(' token
satCheck = (abs.(gps.satCheck.value());
flight_logger:69:24: error: 'class TinyGPS' has no member named 'satCheck'
flight_logger:69:41: error: expected ')' before ';' token
flight_logger:79:6: error: expected '(' before 'speedCheck'
if speedCheck > speedMax {
flight_logger:91:1: error: expected ';' before '}' token
flight_logger:95:1: error: 'oled' was not declared in this scope
oled.setCursor(100, 80);
flight_logger:98:39: error: invalid use of non-static member function 'void TinyGPS::get_datetime(long unsigned int*, long unsigned int*, long unsigned int*)'
String Temps = String(gps.get_datetime)
In file included from /Users/Taran/Documents/Arduino/flight_logger/flight_logger.ino:4:0:
/Users/Taran/Documents/Arduino/libraries/TinyGPS/src/TinyGPS.h:65:8: note: declared here
void get_datetime(unsigned long *date, unsigned long *time, unsigned long *age = 0);
flight_logger:102:16: error: 'data' was not declared in this scope
data.println(gps.get_datetime, +String(gps.f_speed_kmph), +String(gps.f_altitude);
/Users/Taran/Documents/Arduino/flight_logger/flight_logger.ino:102:16: note: suggested alternative: 'atan'
atan
flight_logger:102:71: error: invalid use of non-static member function 'float TinyGPS::f_speed_kmph()'
/Users/Taran/Documents/Arduino/libraries/TinyGPS/src/TinyGPS.h:90:9: note: declared here
float f_speed_kmph();
flight_logger:102:96: error: invalid use of non-static member function 'float TinyGPS::f_altitude()'
/Users/Taran/Documents/Arduino/libraries/TinyGPS/src/TinyGPS.h:85:9: note: declared here
float f_altitude();
Multiple libraries were found for "Adafruit_SSD1306.h"
Used: /Users/Taran/Documents/Arduino/libraries/Adafruit_SSD1306
Not used: /Users/Taran/Documents/Arduino/libraries/Adafruit_SSD1306_Wemos_Mini_OLED
exit status 1
this is the code for your reference:
#include <SPI.h>
#include <Wire.h>
#include <TinyGPS.h>
#include <SoftwareSerial.h>
#include <SD.h>
#include <Adafruit_SSD1306.h>
// --------------------------------------------------------------------------initialising the display------------------------------------------------------------------------------------------------------------------------------------------------------
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define display_RESET -1 // since sharing reset pin with Arduino
#define SCREEN_ADDRESS 0x3C
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, display_RESET);
const int cs_sd = 2;
static const int RX = 3, TX = 4;
static const uint32_t gps_baud = 9600; // might need to change later on depending on sensitivity and speed requirements.
TinyGPS gps;
SoftwareSerial ss(RX, TX);
int speedMax = 0, speedCheck = 0;
int heightMax = 0, heightCheck = 0;
int satMax = 0, satCheck = 0;
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS))
Serial.println(F("SSD1306 allocation failed"));
for (;;); // Don't proceed, loop forever
display.clearDisplay();
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(15, 40);
display.write("VP-DK Avionics");
display.write("Flight Logger ver1.0");
delay(2000);
Wire.begin();
ss.begin(gps_baud);
if (!SD.begin(cs_sd));
display.write("Default Card.");
File data = SD.open("Flight Logger.txt", FILE_WRITE);
data.println(" ");
data.println("Data acquisition started");
data.close();
display.print("Max Speed: ");
display.print("Max Height: ");
display.println(" ");
speedCheck = (gps.f_speed_kmph());
speedMax = speedCheck
display.setCursor(10, 80); // might have to change later
display.print(speedMax);
heightCheck = (gps.f_altitude());
if (heightCheck > heightMax) {
heightMax = heightCheck
display.setCursor(50, 80); // might have to change later
display.print(heightMax);
oled.print(satCheck);
new list of errors. I'm really bad at diagnosing in C, hence asking for help.
Arduino: 1.8.13 (Mac OS X), Board: "Arduino Uno"
In file included from sketch/flight_logger.ino.cpp:1:0:
flight_logger:69:25: error: invalid use of member function 'short unsigned int TinyGPS::satellites()' (did you forget the '()' ?)
satellites = (abs(gps.satellites.value()));
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/Arduino.h:94:18: note: in definition of macro 'abs' #define abs(x) ((x)>0?(x):-(x))
satellites = (abs(gps.satellites.value())); ^
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/Arduino.h:94:24: note: in definition of macro 'abs' #define abs(x) ((x)>0?(x):-(x))
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/Arduino.h:94:29: note: in definition of macro 'abs' #define abs(x) ((x)>0?(x):-(x))
flight_logger:83:3: error: expected ';' before '}' token
flight_logger:91:3: error: expected ';' before '}' token
flight_logger:96:29: error: 'satellites' cannot be used as a function
display.print(satellites());
flight_logger:98:42: error: invalid use of non-static member function 'void TinyGPS::get_datetime(long unsigned int*, long unsigned int*, long unsigned int*)'
String Temps = String(gps.get_datetime);
flight_logger:102:51: error: invalid use of non-static member function 'long unsigned int TinyGPS::speed()'
data.println(gps.get_datetime, +String(gps.speed), +String(gps.altitude);
/Users/Taran/Documents/Arduino/libraries/TinyGPS/src/TinyGPS.h:74:24: note: declared here
inline unsigned long speed() { return _speed; }
flight_logger:102:74: error: invalid use of non-static member function 'long int TinyGPS::altitude()'
/Users/Taran/Documents/Arduino/libraries/TinyGPS/src/TinyGPS.h:68:15: note: declared here
inline long altitude() { return _altitude; }
exit status 1
code has a few changes:
#include <SPI.h>
#include <Wire.h>
#include <SD.h>
TinyGPS gps;
int satMax = 0, satellites = 0;
delay(2000);
Wire.begin();
ss.begin(gps_baud);
data.println(" ");
data.close();
if ( speedCheck > speedMax) {
display.setCursor(100, 80);
Nope, it added it for some reason on its own, should I put the errors in tags as well?
doing it here just for ease.
flight_logger:64:23: error: invalid use of member function 'short unsigned int TinyGPS::satellites()' (did you forget the '()' ?)
satCheck = (abs(gps.satellites.value()));
flight_logger:91:17: error: 'satellites' was not declared in this scope
/Users/Taran/Documents/Arduino/flight_logger/flight_logger.ino:91:17: note: suggested alternative: 'atexit'
atexit
flight_logger:93:41: error: invalid use of non-static member function 'void TinyGPS::get_datetime(long unsigned int*, long unsigned int*, long unsigned int*)'
flight_logger:97:58: error: invalid use of non-static member function 'float TinyGPS::f_speed_kmph()'
flight_logger:97:83: error: invalid use of non-static member function 'float TinyGPS::f_altitude()'
float f_altitude();
exit status 1
option enabled in File -> Preferences.
Arduino: 1.8.13 (Mac OS X), Board: "Arduino Nano, ATmega328P"
flight_logger:60:21: error: invalid use of member function 'short unsigned int TinyGPS::satellites()' (did you forget the '()' ?)
satCheck=(abs(gps.satellites.value));
flight_logger:69:21: error: invalid use of member function 'long unsigned int TinyGPS::speed()' (did you forget the '()' ?)
speedCheck = (gps.speed.kmph());
flight_logger:87:17: error: 'satellites' was not declared in this scope
/Users/Taran/Documents/Arduino/flight_logger/flight_logger.ino:87:17: note: suggested alternative: 'atexit'
atexit
flight_logger:89:41: error: invalid use of non-static member function 'void TinyGPS::get_datetime(long unsigned int*, long unsigned int*, long unsigned int*)'
flight_logger:93:46: error: invalid use of member function 'long unsigned int TinyGPS::speed()' (did you forget the '()' ?)
data.println(gps.get_datetime, +String(gps.speed.kmph), +String(gps.altitude);
flight_logger:93:79: error: invalid use of non-static member function 'long int TinyGPS::altitude()'
exit status 1
#include <SPI.h>
#include <Wire.h>
#include <SD.h>
TinyGPS gps;
delay(2000);
Wire.begin();
ss.begin(gps_baud);
data.println(" "); data.println("Data acquisition started");
data.close();
if (speedCheck > speedMax) {
speedMax = speedCheck;
heightMax = heightCheck;
There is so much wrong with your use of the TinyGPS functions that it is difficult to know where to start
For instance in your code you have
when it should be
I suggest that you compare your use of the functions with how they are used in the TinyGPS examples which is where I found the above syntax for the speed function
I made those changes as well, looked at the keywords and made the required adjustments, but there is till an error. messages and code below.
my apologies for troubling you so much.
flight_logger:65:21: error: invalid use of member function 'short unsigned int TinyGPS::satellites()' (did you forget the '()' ?)
display.print(satellites);
atexit
float f_altitude();
exit status 1
#include <SPI.h>
#include <Wire.h>
#include <SD.h>
TinyGPS gps;
delay(2000);
Wire.begin();
ss.begin(gps_baud);
if (!SD.begin(cs_sd)); {
data.close();
