expected unqualified-id before 'while'
I’ve been looking over and over the code and can’t see anything wrong but there has got to be. I would appreciate if someone could help me out here. I’m just trying a simple repeating loop. The code is below.
Thanks in advance.
Blink
Turns on an LED on for one second, then off for one second, repeatedly.
The circuit:
  • LED connected from digital pin 13 to ground.
  • Note: On most Arduino boards, there is already an LED on the board
    connected to pin 13, so you don’t need any extra components for this example.
Created 1 June 2005
By David C
based on an orginal by H. Barragan for the Wiring i/o board
int ledPin = 13; // LED connected to digital pin 13
unsigned long time; //
// The setup() method runs once, when the sketch starts
// initialize the digital pin as an output:
pinMode(ledPin, OUTPUT);
// the loop() method runs over and over again,
// as long as the Arduino has power
while (time <= 50) {
digitalWrite(ledPin, HIGH);
delay(time);
digitalWrite(ledPin, LOW);
delay(time);
if (time < 49) ;
time++;
else;
time = 0;
You need the void loop() { } construct around the while () construct.
you’re missing the “void loop()” function. Try the following code:
delay(time);
delay(time);
if (time < 49) ;
time++;
else;
time = 0;
if (time < 49) ;
Lose the semicolon (and please use the Code (#) button when posting code)
The void loop and loosing the semi worked like a charm, at least I can compile it, thanks a lot. :)
