expected unqualified id '.' token
I get that error message when trying to complile and I can’t figure out why?
The code is attached. Please help!
Flexcode.txt (510 Bytes)
compiles fine for me
int flexSensorPin = A0; //analog pin 0
void setup(){
void loop(){
  int flexSensorReading = analogRead(flexSensorPin);
  Serial.println(flexSensorReading);
  //In my tests I was getting a reading on the arduino between 512, and 614.
  //Using map(), you can convert that to a larger range like 0-100.
  int flex0to100 = map(flexSensorReading, 512, 614, 0, 100);
  Serial.println(flex0to100);
  delay(250); //just here to slow down the output for easier reading
And for me too, in Arduino V1.6.5.
@mjohnston0889, try again, and if you still get errors, enable verbose output, (>File >Preferences), and try once again, then post the full error message here, (between code tags </> of course). :slight_smile:
And the compiler will highlight the line that the error is on, so let us know which line, too.
