Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno"
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x10
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x10
avrdude: stk500_set_extended_parms(): protocol error, expect=0x14, resp=0x10
avrdude: stk500_initialize(): failed
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
the selected serial port
does not exist or your board is not connected
option enabled in File -> Preferences.
I'm using Arduino UNO Clone , experiencing the following error while uploading 'blink' sketch, have restarted the IDE/Computer and change the cable and usb port. Nothing worked.
