Explain: a line about LED strip
hi i have a little problem i don´t understand what this line does
leds = CHSV(i - (j * 2), BRIGHTNESS, SATURATION);
*the full code: *
*#include <FastLED.h>
#define NUM_LEDS 60      /* The amount of pixels/leds you have /
#define DATA_PIN 7      /
The pin your data line is connected to /
#define LED_TYPE WS2812B /
I assume you have WS2812B leds, if not just change it to whatever you have /
#define BRIGHTNESS 255  /
Control the brightness of your leds /
#define SATURATION 255  /
Control the saturation of your leds */
CRGB leds[NUM_LEDS];
  FastLED.addLeds<LED_TYPE, DATA_PIN>(leds, NUM_LEDS);
  for (int j = 0; j < 255; j++) {
    for (int i = 0; i < NUM_LEDS; i++) {
      leds[i] = CHSV(i - (j * 2), BRIGHTNESS, SATURATION);
    FastLED.show();
    delay(25); /* Change this to your hearts desire, the lower the value the faster your colors move (and vice versa) /
HSV is Hue, Saturation and Value (Brightness) - an alternative to RGB if you like.
The CHSV function calculates the representation for a HSV value to store in leds Check the definition of leds if you need to.
I believe the BRIGHTNESS and SATURATION are the wrong way round in that call, however since both are specified as 255 it probably means you will see no difference.
Have a look at http://fastled.io/docs/3.1/struct_c_h_s_v.html
