Explain please!!!
This code is from the adafruit website, named Measuring SPL readings.
It prints the vales from 0 - 1023 but i don’t understand why i dont get any negative values as its a peak to peak output.
Could someone please explain?
Example Sound Level Sketch for the
Adafruit Microphone Amplifier
const int sampleWindow = 50; // Sample window width in mS (50 mS = 20Hz)
unsigned int sample;
   unsigned long startMillis= millis();  // Start of sample window
   unsigned int peakToPeak = 0;   // peak-to-peak level
   unsigned int signalMax = 0;
   unsigned int signalMin = 1024;
   // collect data for 50 mS
   while (millis() - startMillis < sampleWindow)
      sample = analogRead(0);
      if (sample < 1024)  // toss out spurious readings
         if (sample > signalMax)
            signalMax = sample;  // save just the max levels
         else if (sample < signalMin)
            signalMin = sample;  // save just the min levels
   peakToPeak = signalMax - signalMin;  // max - min = peak-peak amplitude
   double volts = (peakToPeak * 5) / 1024;  // convert to volts
   Serial.println(peakToPeak);
How can any value in the range 0 to 5V be negative?
So its not peak-to-peak, its peak?
Is the DC offset 512 then?
Quote from the Article you got the code from:
The output will have a DC bias of VCC/2 so when its perfectly quiet, the voltage will be a steady VCC/2 (1.65v).
So if you power it from 3,3V then with no input you will read 1,65V aka 1,65V / (1024 / 5V) = 337. Max negative peak will be at 0V (that's negative to Vcc/2) aka 0. And the positive peak will be at 3,3V aka 3,3V / (1024 / 5V) = 675.
Im so confused. When i upload it to print volts. it is sitting at 0.23
does the DC bias actually matter?
Have you read the code at all?
So it does not print what it reads directly but the found peak to peak value. And a peak to peak value is always a positive number because we treat is as a absolute value.
One really wonders what prompted this line!
A reading of 1024 or higher from a 10 bit ADC would be an impressive achievement…
Someone had a bad day at the Adafruit office... :p
